Rosewood Coffee Table *PIX* *LINK*
HC Sakman
>Hi Everybody,
I just finished this simple(!) design coffee table in Siamese rosewood (Dalbergia beriensis) Overall 17" high, the top is 44"x47"x6". I built it upon a torsion box construction. It's all veneered with shopsawn 3/32" thick veneers. The end caps look like solid boards, but actually they're not. I glued end grain solid stock at both ends of the substrate, then veneered over outside face and edges. Finally all edges are rounded over with 1/8" radiused bit and it sure looks like solid wood.
It's such a strong, dense wood, even at this (3/32") thickness, it gave me a great grief on jointing and keeping the whole thing flat. Since it's air dried, it gets effected by temperature changes a great deal, although it just buckles as it heats up (under the sunshine) but dimensionally stable.
The base is just ebonized Baltic birch plywood box, setback 6" on all sides. Finish is oil-varnish rubbed on many coats. This rosewood is not oily at all, so varnish dried fine.
Thanks,
Chico...
My website
