Veneering
Veneering
Veneering
David
>I have never veneered before. I have a small aircompressor. What is the best set-up in the $300-400 range for small lamp table tops, table aprons, etc. I remember the virtues of vacuum presses that run off an air compressor needing less maintainence(?) Thanks in advance. David
Re: Veneering
Re: Veneering
John_in_Az
>Hi David - I'm in the same boat as you and started looking for a vacuum press system also. I found a site (joewoodworker.com)that has most if not all the info needed. I think you are referring to the "venturi effect" system that uses your compressor and not a separate vacuum motor system. I think you can get that system for around $300 including the bag. Also you can save a few bucks by making your own bag and he sells all the stuff needed for that. BTW, Joe seems to be highly regarded in this area from several reliable sources. Good luck, John
Re: Veneering
Tradeoffs
>The best air bag systems use dedicated vacuum pumps to evacuate the air and hold the vacuum. I consider them superior (although the pump is a lot pricier than the venturi attachment) because you don't have to listen to your compressor all day and night while your glue dries. That said, my first vacuum press consisted of a 1/2-HP cow milking pump I got at a yard sale for five bucks and a piece of clear vinyl slip-cover from a cut-rate upholsterer. It leaked like a sieve but did the job, until the motor burned out. You pay more for efficiency and convenience.
Ellis Walentine, Host
Re: Veneering
Re: Veneering
Brian Gray in Sandusky, OH
>If you are starting out with only small projects, and just getting your feet wet with veneering, it might be better to build a manual press.
Then figure out how interested you are and upgrade at another time if needed.
Re: Veneering
Re: Veneering
Tony - Memphis
>I did a couple of projects with melamine boards and clamps. That worked pretty well for small panels and tabletops. But I wanted to do more and bigger, so I started investigating. I ended up with the Vacupress home kit. I ordered it with a larger bag for a specific project (tall dresser). I've been really happy with the setup. Vacupress is very supportive. They have a forum where you can get lots of info. I've used mine for several projects and had no issues. I bought it directly from them. I looked at the build your own stuff, but my time is pretty limited and I'd rather use it to do the woodworking than tinker with building a press. Someday, I'm going to graduate to using it for some of the more tricky stuff. Just haven't gotten there yet.
Tony
Re: Veneering
Re: Veneering
McKay
>I am not an expert, but I have done some panel and curved veneering with a polybag and the QVP (quality vacuum products) . I have had some good success, and also some expensive screw ups. The more figured the veneer, the more problems may arise. I just recently purchased and put the venturi system from joewoodworker. It works very well and for much less than the QVP. (QVP system is borrowed so I made the system from joewoodworker) I have purchased veneer from Certainly wood, The Dean Company, Paul Schurch woodworking, and joewoodworker. All were great to work with. (Colored veneers from Paul Schurch and Dean Company. I use a drafting program to make the designs to the desired size.
Re: Veneering
Re: Veneering
Michael Wilkins
>Woodcraft sells a vacuum veneering system for around $329.00. I would be more inclined to get a system made specifically for veneering than cobble together something. The Woodcraft unit has the vacuum pump, 54" X 54" bag, hoses and instructions, and works great. I have done both flat and curved glue-ups, and in my opinion, a great system for the serious amateur.
Just my 2 cents worth.
Re: Veneering
Re: Veneering
McKay
>I have the pump that Michael mentions. I have not been real happy with the speed. I used the pump for vac clamping on my denray table, and switched to the venturi for speed and vac. pressure.
Re: Veneering
Re: Veneering w/contact cement
paul in AZ
>Ok, here is some experience from the pre-pump dark ages.
I built a couple of harpsichords many, many years ago. Part of the work involved veneering birch ply cases [most historic instruments are painted but I am a lousy painter], one in walnut and the other in cherry with some holly and fancy inlays.
The sheets of veneer were over 6 feet long X about 1 foot wide on the spine; almost that size on the bent side; and ~6ft. X around 4ft on both sides of the lid. For those who can't visualize a concert size harpsichord, think of a grand piano 7 feet long. Same shape.
I used contact cement for all of this. Once the cement is fully dry, I put down waxed paper and laid the veneer on top of that. Then, carefully pulled the paper out using a wooden veneer roller as I pulled the wax paper out to make sure there were no air bubbles. Once all the paper was out I went over everything with the roller several times.
It was only then that my knees stopped shaking. Talk about a nervous sweat!
So far the veneers have held for 30 odd years.
Not very high tech but effective.
Small projects of a couple of square feet are a piece of cake to do with contact cement and a veneer roller.
