OT: Fiberglass repair question
Tom MacGregor
>I've started driving a rust-bucket '95 Honda that gets twice the mileage of my pickup when I don't need to haul stuff. It needs some extensive patching & I want to "paint" resin on the bad panels, apply fiberglass cloth to the wet resin and then thicken it up with another coat. Does anyone know how to slow down how fast the resin sets up & give me a little more working time?
Re: OT: Fiberglass repair question
do the work when it is cooler
Grant in Iowa
>Generally, resin sets slower when the temp is cooler. You may also be able to find some retarder that is compatible with the resin you are using.
Further, make sure your pot is a shallow pan, not a cup or bucket type shape. You can also prolong pot life by putting your pot in some ice water, though too much of this can make the resin hard to work with.
West System has some great books they'll send you on the subject.
FWIW,
Grant in Iowa<---not a resin expert, but I've done it a few times...
Hijack - Grant, how's things in CR?
Tim Greif - West of Chicago
>A friend of mine in Cedar Rapids tells me that what we're seeing on TV does not begin to tell the level of devastation you have there. You survive ok?
Jesper, Denmark
Jesper, Denmark
>If you are using epoxy resin, you should have at least half an hour to work with it. Then you need to wait several hours before you apply the second coat or Bondo.
If you use regular polyester, it may only be 15 minutes, but then you can apply Bondo as soon as it is solid enough not to smear.
Rough the metal up good before you patch and clean it for any rust or oil, or it will come off rather soon.
THIS METHOD IS NOT SUITABLE FOR EPOXY RESIN
Robin Corell in Atascadero CA
>If you are using polyester resin you can get away with using only a fraction of the amount of hardener, particularly if you will be putting multiple coats on. the trick is to do a final coat of resin with the correct amount or even a bt more and this will kick the previous layers. This will take longer for everything to cure and if you have some thick areas it can cause excess shrinkage. I should also add that you should be allowing each coat to kick and cool before adding another. and as someone has previously stated you should be using a large shallow bucket vs a deep bucket and you ahould be using a clean bucket or one that has cooled down for each batch as well as a fresh brush and stir stick.
Another trick that can speed up glass repar work is to pre wet your cloth before applying. use a piece of heavy plastic and slap a brush full of resin on the plastic and spread it out then lay your cloth down and brush out the surface. while the cloth is wetting out brush the surface you will be applying the cloth to. then when applying the cloth place the side that you brushed out more resin on down. Use the brush to poke and push all the bubbles out as well as to force out any excess resin. I should add here that the goal in glass work is to use as little resin as possible. fiberglass should not be used to fill with but rather to build for strength.
Robin
Re: Hijack - Grant, how's things in CR?
Grant in Iowa
>Tim,
My wife and I built a home last summer on some of the highest ground in the county...we are lucky.
Downtown Cedar Rapids there are block after block after block of devastation. The downtown government offices are all closed(moved) and about 2/3rds of the downtown business district are all flooded on the first level. Countless small businesses are without a storefront now.
I have been helping my Nephew clean up his Fiance's house which is 9 blocks from the river. It was flooded to a depth of about 6" on the first floor, including of course the basement. What a mess. We are done cleaning and are now rebuilding, but most homeowners are still in the cleanup stage.
If you want to see more, go here and click on flood of 2008:
Thanks for asking, we are hanging in there and pulling together.
Re: Here's the link  *LINK*
Grant in Iowa
KCRG
Re: THIS METHOD IS NOT SUITABLE FOR EPOXY RESIN
Joseph Mulherin, Sr
>I agree with Robin on how to work the resin. Years ago I worked on an Alfa Romeo fender...the battery in the trunk area spilled the acid and it ate the metal away leaving a sizable hole. I measured my cloth, laid it on a plastic sheet, coated the cloth with the resin and then sprayed the resin with the hardener provided, picked up the sheet and applied it to the fender...smoothing out any wrinkles, etc. Let it set for a few hours and applied another coating of mixed resin/hardener with a small disposable paint brush. Sanded the hardened finish, and applied a thin coat of Bondo and smooth sanded when finished. Repainted the entire car an International Orange color that looked wet when it was standing at the curb....looked like the paint was ready to roll off. Painted nine cars that year and that one was the best of all.
