ADVERTISE HERE - FREE TRIAL
Removing surface rust from TS wing
Dan Mitchell
>Since it is about the only absolutely flat surface of any size in my shop, I sometimes use my TS as a glue-up area. I generally put down newspaper to absorb any glue leakage, but yesterday I ended up with a long streak of rust about 1" x 24" long from glue soaking through the paper. I've removed the bulk of it with steel wool, but there is still a grayish stain. Can anyone recommend a chemical remover or other approach to eliminate this stain? I do need to slap on some fresh wax, I know...
TIA
Dan
Re: Removing surface rust from TS wing
Re: Removing surface rust from TS wing *LINK*
>I don't usually use steel wool. I find that a fine "scotchbrite" type pad cleans better for me.
I had to rehab some old rusty tools that I inherited. I used Rust Free to fairly good effect (though for severe cases, I've used Naval Jelly).
Highland Woodworking - Rust Free
Ken Oakley-Sunny St. Cloud, Fla
>I use 320 or 400 grit wet dry sandpaper. I live in Florida and my machines are in my 2 car garage so you know rust is a given down here. Putting wax on helps but as soon as you use the machine the coating wears off and rust returns. I went to a local cabinet shop and got a piece of 3/4" Formica covered Plywood that was cut out of a countertop for the sink. I put that on my Unisaw for doing glue ups.
>Hello Dan,
I find that a random orbital sander equipped with 320 grit removed rust and other marks quickly. I usually dampen a paper towel with naptha and wipe off the residue, then paste wax. I do it every month or when ever necessary. You may consider putting down sheet plastic over the table top before using it for glue ups. It'll stop moisture from defacing your table.
George
Larry Clinton At Frankfort (Central)., Indiana
>I use one of the fine sanding sponges and wd40 (or other penetrating oil) to wet sand until the rust and stain is removed then clean with mineral spirits or paint thinner before re-waxing. By the way a couple of years ago I hit upon using the plastic tablecloths to cover my saw, floor, etc. when stains or glue. They have a cloth backing and you can pick them up at Salvation Army, Goodwill, yard sales and occasionally at Wally world (marked down to a dollar or two). I have several in the shop and they beat the plastic drop cloths all to heck. They last a long time, I'm still using some after 2 years of use.
Robin Corell in Atascadero CA
>I use my table saw top for glueing up all the time. I use a razor blade to remove any rust/glue and I don't worry about the bluish stain that is left. Keep gluing and eventually the whole top gets a patina. It is a tool and meant to be used- that my story and I'm sticking to it.
Robin
Dan Mitchell
>Thanks for the replies. I had just been using newspapers because I have them handy, but plastic is a better idea. I especially like the tablecloth approach - definitely going to snag a couple for the shop.
Dan
Jim Dillon
>Dan,
I've had luck with the Abrasor sanding block sold by Klingspor. I squirt on some WD-40 or whatever I have handy and have at it. But even then, I sometimes am left with a slight blueish/gray discoloration. I then rewax the top and keep it covered when not in use with an old flannel sheet. For glue-ups, I have a partial roll of resin paper left over from a hardwood flooring job and I use that under the work piece. If the workpiece will be right against the resin paper, I place a piece of wax paper between the resin paper and the work piece.
Jim
Klingspor Abrasor Sanding Block
