THE WOODRAT IS BACK!
Can we spray lacquer over a coat of wipe on poly?
North of the Border
>Also, does a surface coated with lacquer provide protection against water or moisture? Thanks.
Re: Can we spray lacquer over a coat of wipe on poly?
HC Sakman
>No, you shouldn't do that. Solvent in the lacquer will make poly bubble, blister.
Lacquer can go over oiled (no varnish/poly in it) surface though.
Chico...
Ken Oakley-Sunny St. Cloud, Fla
>I have had sucess by spraying light coats of Krylon Clear Matte spray on surfaces that are attacked by the solvents in lacquer and then spraying light coats of lacquer on top of that. I would practice on a piece that can be discarded before spraying a finished piece.
Fred Davis
>Lacquer over poly doesn't work as H.C. pointed out.
About moisture protection , Lacquer ranks low .
The best you can do with Lacquer for moisture protection is use a Pre-Cat CAB lacquer which is applied over a sanding sealer which has Vinyl in it and the Vinyl is the agent providing the protection.
I used Nitro-Cellulose for years and have pretty much switched to the CAB lacquers because they are tougher and have much more resistance to moisture.
FredD
be wary
Bill Tindall, E.TN
>If the oil is not thoroughly dried the lacquer won't adhere. I had to strip a piece recently for this reason. Fortunately it stripped very easy.
Thank you - will stick to wipe-on poly
North of the Border
Actually it depends on what brand
Robin Corell in Atascadero CA
>Looks like I'll be the contrarian here. based on some recent discoveries on my part it looks like each combination of finishes needs to be explored rather than giving a blanket yes or no answer. I have experemented and found that some will work. I recently finished a project with General's HF poly(a waterbased poly acrylic that looks and sands like nitro cellulose) over uncured Jasco tung oil and I had 100% adhesion. I did some prior tests and know for a fact that the combo I used does not delaminate. The other interesing property is that by putting the tung oil down first the waterbased finish didn't raise the grain.
Anyone shooting lacquer over poly may wish to try switching to one of the new generation waterbased products as they perform better than nitro cellulose and are easier to use and touch up then CAB.
Robin
