Firefox 3 users?
Firefox 3 users?
Firefox 3 users?
Bill Tindall, E.TN
>Anybody downloaded Rev 3? Any reason not to update? Some sites don't work on my ancient version of Firefox and I have to go to Explorer. If Rev 3 fixes this issue I will update. If it doesn't I won't.
Re: Firefox 3 users?
I use it
Michael Dresdner
>I haven't had any problems with any websites, but it sure cured the problems I had been having with Explorer.
Del Williams
>I'm pretty new to using Firefox - been using Version 2 for a month or so. I downloaded Ver 3 this morning and have had no problems with it. All of the existing bookmarks came over fine. I think it really does give a bit of an increase in loading of most webpages (subjective estimate compared to IE6 and a cable modem broadband connection). The bookmark management is an improvement from Ver 2.
Mark J Valsi
>I got it as well, and like it so far, has some nice features !!
David Propst
>Firefox 3 seems faster and has a number of minor new features that add up to a big overall improvement in an already good browser. It took a couple of minutes to upgrade and I've had no problems on 2 computers.
The problem with some sites needing Internet Explorer is not a Firefox problem per se, some sites require IE, but the number of those sites are dwindling. There is a Firefox add-on that will automatically open those sites in an IE tab.
I'm in online grad school at Duke and the IT folks there strongly recommend using Firefox over IE, especially IE7.
David
Howard Norman
>Bill I updated to Firefox 3 on Wednesday. I have had no problems and it does appear to be a little faster. One of the new features that I like is that the Download box now contains the date/time that I downloaded something. The problem with some sites not being accessible with Firefox is the site itself. For the last few months Microsoft is the only site that I have seen the problem.
howard
Dan Donaldson
>I have been using Firefox since it was called Phoenix. I held off on version 3 until the plugins that I use were updated for the final. They are now there, so I am using it with no problems. There are a couple of reasons that some sites will not work with Firefox. The first is that they check for browser type and refuse to load with anything other than IE. In many cases, you can get around this by installing the user agent switcher add on and telling it to lie and tell the site in question that it is IE. This works a lot of the time. The other reason for sites not loading is because they use Directx, which is intentionally not supported in Firefox. Directx is the source for a lot of the security bugs in IE. In general, unless there is a VERY compelling reason that I need a site, if it is IE only, then they have decided that they don't need me and I accommodate them.
John McGaw
>Works fine for me. I've been using it since the last beta and through all of the release candidates. If you use some obscure plugins then you may find that they still have not been updated but all of those in the mainstream seem to be good to go.
Will Abbott
>I use it and haven't had a problem with any site in a long time.
I tend to do the same thing
Curt Harms
>and I tell 'em WHY I don't use their site.
John in Ks
>I loaded it last nite after reading this posting and am impressed how much faster it is. So far no problems.
John
"user agent switcher add on" how to?
Bill Tindall, E.TN
>How do I find and install this convenience? As far as the sites I have bookmaked in Explorer because they don't work well with my current old version of Firefox: one is Netflix and the other is a client that pays me when I work for them.
Bill Tindall, E.TN
>Thanks to all. Will download tonight.
here is a link *LINK*
Dan Donaldson
>Here is a link to the add-on. Just click on the "add to firefox" button to install. You will need to restart Firefox afterwards. After installation, if you click the tools menu, there will be a pick for the switcher. You can select ie7, netscape, or opera out of the box and in the options menu, you can add other browsers. This won't work all of the time, but in many cases it does. (as long as the problem is not directx)
A few other very useful addons are:
Cooliris--This gives you the ability to preview links in another box and then close it to return to where you were easily. This works well for reading messages on Woodcentral without having to open a new tab or window.
Flashblock--I really like this one. On any page with flash content, it puts a play button in place of the flash so that you can decide whether to play it or not. This prevents automatic playback when you go to the link. I much prefer this behavior.
Tab mix plus--- This one gives you a lot more control of the tabs in Firefox. Auto open in background tab, hover select of tabs and more. This one was the main reason that I waited to upgrade to FF3. I didn't want to do it until there was a version of this that worked in FF3. I believe that the one I have right now is a dev version, but it works and all is well for me.
The last is noscript--- This one prevents a site from running any scripts unless I give permission. You can make the permission sticky for a given site so that you don't have to keep allowing. I like it because it blocks a lot of the tracking links on many pages and I can just allow the minimum to get the content that I want without allowing stuff like doubleclick and some of the syndication scripts which are tracking sites.
User agent switcher
