Changing sandpaper oscillating sander
Dean Lapinel
>I took off some worn sandpaper drum off one of my spindles and can only get the new sand paper drum half way on (Jet oscillating spindle sander)It is a Jet replacement of the correct size and the top compression screw is off.
There must be a trick I'm missing.
Need urgent help...my daughter is here this weekend and we are doing a project together-
Thanks so much for any reponses!!
Re: Changing sandpaper oscillating sander
>Good Afternoon Dean,
Try to dust the drum with a little talcum powder to lubricate it. The sanding sleeve should slide on more easily. Don't forget to tighten the compression nut once you are loaded up.
George
Dean Lapinel
>Thanks!!
Rats!
Dean Lapinel
>The talc didn't work. I tried all three jet replacements and they all go half way then stick. I'm going to try putting the rubber drum in the freezer for a bit just in case it helps shrink it a little.
Re: Rats!
Don at Central Illinois
>I don't have exactly what you are using but I've had to take the 'spindle' and roll (like a rolling pin) to get it back into it's original shape. It seem's, on mine, that when it is tightend up it doesn't want to go back to the original shape. Hope his helps.
Re: rollingpin
Kneale Brownson Dreaming of the Snow in N. MI
>That's what I've had to do occasionally with the rubber spindles on my Delta oscillator. Seems like tightening the end nut too much makes the rubber too fat to shrink back to the original size.
Re: rollingpin
Phil Joines Krum, Tx
>I put mine (Delta) on the floor with a board on top , push down with my foot and roll it back and forth.
Randy Johnson Connersville IN
>I once caught some flack,I think on another board, for criticizing the Jet spindle sander for the exact problem you are having. The guy who took strongest exception to my comments had never had the problem and we decided that maybe I just had some drums or sleeves that slipped through the QC cracks.
It doesn't solve your problem to know that there is least one other person who shares it with you, but it does indicate that the problem might be more than a fluke. Almost every power tool in my shop is white or gold but I have really been disappointed with the Jet sander. BTW, although they are too short, the Delta sleeves I bought once by mistake seem to fit fine.
My sander is on the floor in an out of the way place and I probably haven't tried using it more than two or three times since moving to the new shop two years ago. The stand I made to set it on is still at the old shop. At least part of the reason for chalking the Jet sander up as a mistake and not even trying to fix the sleeve problem is that I now do mostly round things instead of flat things.
Robin Corell in Atascadero CA
>First I will say that in any good quality OSS with good accurate tolerances this is a common issue. My first tip may not be much help right now but it is the one that usually produces the best results with the least frustration. If you know the drum is shot and should be changed before you will need to use it, release the nut that compresses the drum. It may take overnight or even longer but if the drum is only a few years old it should relax and the old drum will slip off and a new one will slip right on.
Now for the real world solution since most people need to change the drum and continue working as soon as possible. This will work best on resin bonded cloth sleeves. insert the drum as far as it will go, try the board and standing on it routine and then hold the sleeve with the drum sticking out from the top and from a few inches above a solid surface lightly but firmly tap the sleeve on the table. It is very important that the sleeve make contact with the table at a perfect 90* or you will damage the unsupported sleeve. This should cause the drum to slide in a fraction of an inch. Continue this until the drum is all the way in. This technique works 100% of the time and I used it to change more sleeves than I care to count on 9" industrial OSS machines.
Robin
