ADVERTISE HERE - FREE TRIAL
Serenity bench
Serenity bench
Serenity bench
Robin Corell in Atascadero CA
>I just finished this bench and will be delivering it in the AM. It is made from monterey cypress or macrocarpa for those down under. The finish is a bit unusual and is the inspiration for the title. There is a base coat of Jasco tung oil followed by General HF Poly (water base) what makes the finish unusual is that is has a tincture of Chinese medicinal herbs added to it. It was commissioned by a practitioner of Chinese medicine and the herbal blend is one that is supposed to promote calmness and serenity.
The seat has a hand carved texture and the ends of the legs have a wave pattern carved on them. The joinery is loose M&T and the cross members are pinned from the bottom of the legs. The good photos will have to wait until I finish the second bench that is being made on spec.
Robin
Re: Serenity bench
retry on the pic
Re: Serenity bench
Very Cool
>Hey Robin,
Doesn't everybody use herbs in their finishing? ;-) That bench looks like a comfortable sit. The seat almost looks soft by the way you shaped it. I like it!
Tom
Re: Serenity bench
Re: I like the "tie"..
>Did you have a particular problem with the cypress splitting? I did a couple of chair seats out of cypress and a settee and I wasn't too happy with them.
Re: Serenity bench
Re: Very Cool
>It is a comfortable sit and more importantly it is also comfortable to lay down on. I plan on having the spec bench at the Bellevue Artsfair. It is a grueling show with 9:30am-9:30PM hours on Friday and Saturday. Sunday is more reasonable but it will be nice to have a place to lay down. After last year I threatened to make a queen sized bed for the show figuring I might be able to meke more money by renting it out for 30 minute power naps to the other exhibiters.
herbs, 220 221, what ever it takes.
Robin
Re: Serenity bench
>The butterfly is stablizing a crack that developed during drying. Not sure what part of the country you are in but monterey cypress is very diferent from bald cypress. Monterey cypress is similar to poplar in hardness. it carves nicely, though it requires extremely sharp tools and tends to dull them quikly.
It can crack and check if dried too fast but once dry it is very stable and not prone to cracking. it can be a bit on the brittle side and this may be what you are refering to. It can have some squirley grain and sometimes this will cause a nasty blow out when machining. To me this is a workabity issue and not a strength issue and just means that is is more suitable for some things and less so for others.
I have a pair of stools I made out of it and have had no problems and the design is one that does not have any lower cross members. The legs are through morticed in to the seat.
I have a table lamp I make and one of the woods I use is monterey cypress. I love the way it turns and the polish it will take.
Robin
