Waterstone
Waterstone
Waterstone
Sawman
>I would like to add another one to my box. I have been getting along with a 300,800,&1200 but I really need to go up to the next level.
So what brand is reasonably priced? And what grit,4000 and or ?
Re: Waterstone
Moses Yoder
Re: Waterstone
Moses Yoder
>I use a 4000 then 8000. The Norton water stones from Lee Valley I think are a good buy. They are good quality stones and large enough to be comfortable and last a long time. If only buying 1 stone I would use the 8000 as a final but using the 4000 saves wear on the 8000.
Re: Waterstone
Re: Waterstone
Robin Corell in Atascadero CA
>I have a coarse green stone that I rarely use, mostly due to not having a container to keep in in so it is always ready. The majority of my sharpening is done with a 1000 followed by a 4000 water stone and then finished by hand on leather with rouge. for the amount of carving that I do the sharpening set up I have is surprisingly primative and minimal and I have no plans to change it. I have a pair of slips in one tupperwhare container and a pair of cones in another. stacked on top is a piece of wood with a scrap of leather glued on it. underneath the pile is a medium diamond stone for nasty chips and router bits. it too is rarely used.
Robin
Re: Waterstone
Re: Waterstone
>I have a 200x, 1000x, 4000x and 8000x. I've also got a couple of combos (1000x and 4000x).
Re: Waterstone
Re: Waterstone
Larry Clinton At Frankfort (Central)., Indiana
>I have a few King & a full set of Norton combination stones. mostly use the Norton. Lee Valley has the Norton combination stone - 4000X / 8000X for $75.00. You may want to buy a Nagura stone ($7.50) as it does help speed up sharpening. I'm sure you already have one but, I like the truing stone I purchased from LV.
