Re: Honing stones
Bill Tindall, E.TN
>Let me guess that the real issue is that they don't cut as fast as you would like and the thought is that the grits may be plugged up with junk so that the abrasive is not sufficiently exposed, right?
Carrying this assumption forward, indeed the stone may be gunked up with metal particles, or you may be trying to hone one of the more abrasion resistant modern steels that don't abrade very quickly on oil stones.
The problem, in my mind, with old fashion stones is that they don't wear fast enough to expose new sharp edged abrasive particles. The water stones solve this problem by binding the abrasive with weak clay or something so that the worn grit falls off and new sharp particles are continuously exposed.
Ask how to clean the stones on the hand tool forum. There are many over there that used them. I would be inclined to rub them on a diamond stone or some coarse silicon carbide such that a new abrasive surface was exposed, but this is a guess. Any solvent will remove oil. It will take something mechanical to remove metal, or a soak in hydrochloric acid.
