Drill index?
Sawman
>I really need to get a set of drils. Not brad points just regular twist.
Any leads??
Drill index?
Sawman
Any leads??
Re: Drill index?
Gene Gauss
>Go to www.mcmaster.com (McMaster- Carr). You'll be able to select from more different kinds of drill sets than you thought could possibly exist.
Re: Drill index?
Larry in NW Ohio
>I have bought some from Ebay, but I stay with American made. I have bought probablt 3 sets of 29 drills from Sears. I always bought the titainium and paid no more than $50 for each. Larry in Ohio
Re: Drill index?
steve mackay
>I got the high-end Craftsmans. They've served well over the years with one catch . . . that set STAYS in the woodshop and only gets used FOR WOOD. NO HOUSEHOLD OR MECHANIC USE ! Have another index in the garage for general use / abuse.
Re: Drill index?
Tom MacGregor
>I have several sets of bits and use the cheapest type that works to preserve my high-end expensive ones for the tough stuff. I'm not a fan of fancy coatings. I mostly use plain black oxide bits and resharpen 1/8" & up with a Drill Doctor. I use a center punch, keep the speed & feed rates down, drill pilot holes, use a little cutting oil, and resharpen as necessary. Increasing the speed & pressure to force a drill to make a hole when it's not cutting just burns up bits. Avoid cheap 115 pcs. fractional/number/letter sets - they look great on the shelf & don't cut for @#*!.
Re: Drill index?
Dave Anderson (PacNW)
>I have a set of Dewalt Bullet point. They are the best bits I have ever used. They cut clean holes in wood and metal the same. They cost about $60.00 at sears
just 2 cents worth,
Re: Drill index?
Scott Greaves in Blackfoot Idaho
>Of course, all are good suggestions!
But call me cheap! I have and use the 115 piece drill index from our friends at Harbor Freight. Are they the best bits around? No. But they are good bits for general occasional use, especially if you get a Drill Doctor and keep them sharp. Then if you find a couple of bits you use a LOT, invest in a better bit in that size.
Good luck!
Scott.
