THE WOODRAT IS BACK!
OT Demolishing framing questions?
>Been working on my cousin's house. She has me rearranging the interior walls. Usually, I use my Sawzall with a metal cutting blade and run it under the studs to cut the nails. This time, I'm running into huge nails, full sized old school 16d and 20d nails. As many as four per stud. Toe nails. Worse yet, if I try to bump them out with a sledge hammer the studs shatter. I need to ave them because they are not the standard size of studs we have today. In fact I have two different sizes. Some old and some very old. Worse yet, they occasionally used case hardened cut nails. Those things will ruin a saw blade in about ten seconds.
Any suggestions? Have any of you used the demo blades or the nail biter ones.
They also buried a 4 X 6 in a wall sticking out two inches. I need to rip off the part that sticks out. There is a 2x4 on each side of it. Any hints?
Re: OT Demolishing framing questions?
different blades
Ed Snow
>Carborundum or diamond sintered blades might work better.
Justin
>A carborundum or sintered blade will cut very slow & heat up & maybe start loosing carbide. You can either cut 2x6 or larger to make up for the size differential, use 2x4 & rip strips of OSB to pack things out, depends on what is cheaper, material or labor. Beating the stud out is the easiest, fastest way. I once was offered a job for a general contractor who required you supply your own tooling. I could imagine spending half a days pay for sawzall blades in as much time doing demo you described. Best to rip out & start anew in a situation like you have.
Justin
>If I understand the situation, can you cut above the nails, pry out what's left of the stud with a wrecking bar, then clip off the nails?
I usually use a good bimetal blade labeled for wood with embedded nails. Not much good on hardened cut nails, though.
The best blade I've found
Neal in San Jose
>I've had good luck with a blade called the "Torch" by Milwaukee. Not cheap, but if your time is worth anything, they are cost effective. They are available at my local borgs in 6 inch, 9 inch, and 12 inch lengths and 18 and 24 teeth per inch. The 18 seems to be the best for demo work, but they do get hot and don't work all that well for general cutting (wood only). I've used them on everything fron nail infested wood up to re-bar. They do get dull, so expect to go thru several. I've had luck extending their life by using the longer blades and trying to use different parts of the blade; not just the part right next to the Sawzall. Helpful when up in an attic or down in a crawl space and you don't want to be changing blades every minute. I've been known to have two recip saws on the jobsite loaded with different blades; one a "Torch", the other a coarse tooth bimetal.
On your odd-sized studs, would it make sense (time-wise) to just blow out the existing studs and rip new ones out of 2x6? You can make them any size you need. I've found studs as old as you are describing to be hard as concrete, and just about as prone to splitting. Might lower the blood pressure a little!
Re: The best blade I've found
Larry in NW Ohio
>Barry I wonder could you cut the board that the stud is setting on and nailed to and cut it on both sides of the stud, down to the floor and take a short 2X4 and pound the stud out with that. Or chew it out somehow, I can`t think of everything[:-)))) At least you could get at the nails then. From here it sounds pretty good or am I missing something. If you could get at the nails, then you couls take a grinder and cut them out. Good Luck Larry in Ohio
>Thanks guys.
The 4 x 6 is a tee post. It has studs nailed to two of the 6" sides. Not only that, the house has diagonal sheeting. 1 x 6 boards nailed to the outside. So, I know darn well they nailed the sheeting to the back of this post. From the number of nails use else where I bet there a bunch of them. I think I am going to rip it in place with a chain saw.
On cutting the nails on the bottom of the studs, I found that driving a pinch bar (wonder bar?) under the stud, creating a small gap makes the job easier. And looking a little harder and avoiding the case hardened nails has saved a few blades.
I had one Milwaukie bi-metal blade. Didn't think that would be enough, so I bought a ten pack of blades I thought were also Milwaukie. (They were white and hanging on the same rack in the Borg.) Turns out they were Mol or some such thing. They say "made in USA", but they are not as tough as the Milwaukie blades. About a four or five to one difference.
I have been doing it like that,
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I have been using the long lenox bimetal blades. But the last pack of blades were not only bimetal, but were also TIN coated. So far, I think they are a good improvement, I have not had to replace the first one yet.
You are probably are already aware that on the Rockwell scale, with diamond at 100, carbide is about 75, but the titanium nitride is somewhere half way in between, so coating an already hard tooth should really help.
