How many gallons of gas are in a barrel of oil?
Lee Grindinger
>I suspect someone here knows the answer to this question and I thank you.
By the way, this is not a rant or should it be used to start one, I'm just wondering...,
Lee
Lee Grindinger
Lee
Re: How many gallons of gas are in a barrel of oil
Larry in NW Ohio
>If I remember correctly I think there are 55 gals in a barrel. Larry in Ohio
Gene Gauss
>A barrel of oil is 42 gallons and makes 19.5 gallons of gasoline. See the website "www.gravmag.com/oil.html" That website has a lot of info about petroleum/oil/gasoline that ought to be of interest to all of us these days of high fuel prices.
How many are converted to gasoline?
Lee Grindinger
>There is a lot of other stuff in crude oil.
Lee
Give that man a cigar!
Lee Grindinger
>Thanks, that's exactly what I was looking for.
Lee
And more...
Jason Roehl in Lafayette, IN
>What I've gleaned from a variety of sites over the last few months is that a barrel of crude is 42 gallons, but with the additives and such, about 48-49 gallons of product comes from a barrel. Also, older processes produce the 19.5 gallons of gasoline mentioned above, but there are some newer procedures that allow refiners to crack more hydrocarbons, so that up to 28-29 gallons of gasoline can be extracted from a barrel of crude. More common is in the low 20's.
Jason
Another cigar, please!
Lee Grindinger
>Thanks
Different Crudes
Kevin Rabenaldt
>Crude oil is not the same. One typical measurement is the API gravity. You have heavy oil (like in California) that is API 8 to 10 and will not flow under normal temperatures and pressures and requires that steam be injected to heat the oil and allow to flow. When price of oil was low, produces of this crude were losing money on this crude, but you can not stop the steam injection because the oil would set up again and it takes alot of energy to create the steam. So costs are high per barrel to produce. There is alot of heavy oil. West Texas Sour is usually 25 to 28 degree API. Alot of sweet crudes are 35 to 40 API.
You can get more gasoline out of the higher API crudes. And generally the price of you get for the higher API crudes is higher as well. The posted price varies then according. What we hear on TV is the posted price for the sweet crude I believe.
In addition, heavier crudes are more expensive to refine. Refineries are designed to handle certain types of crudes, that is why the Alaska crude is not refined on the West Coast.
The oil industry is a very complicated industry, much more that people realize.
Kevin
Re: Different Crudes
John in Calgary
>And an interesting extension of this - as the demand for gasoline goes up (not the demand for crude), the price of oil will increase as more people chase the limited supply of lighter crude that is easier to refine into gasoline than the heavier crude products (which require special refineries designed to process the heavier blends into products).
John
Lynn Baker in snowy Glacier, WA
>The West Coast refinery of BP in Ferndale, WA would be quite suprised to hear that they could not process Alaskan crude since they have refined nothing else since the ALEYSKA pipeline delivered the initial tanker loads to Valdez in the 1970's. Your other comments about the properties of crude oil are right on the button though.
Lynn
Is that a trick question?
>"...How many gallons of gas are in a barrel of oil? ..."
The answer is: none.
Reminds me of joking around with the kids last weekend....
Say "toast" three times.
Spell the word "toast".
Say "toast" two more times.
Spell the word "toast" again
Say "toast" four more times.
What do you put in a toaster????????
Happy Woodworking!
'Splain this, please.
Ron Bauman
>If a barrel provides 20 gals. of gasoline and I divide that into $130 a barrel why aren't we paying $6.50/gal or even more? I know some of the rest of the barrel goes for other uses, but it stumps me.
Vintage Crude
Stuart Johnson
>Some vintage crude I got in the eighties.
All around the country from coast to coast...
>People always say, "What do you like most?"
Now I don't wanna brag, I don't wanna boast,
I always tell them, "I like toast!"
Yeahhhh, toast!
But you put bread in a toaster...
Jason
Re: 'Splain this, please.
>Read through the other posts.
A 42-gallon barrel of crude yields about 48-49 gallons of product (due to refining and the additive packages). What isn't turned into gas (light, low comparative BTUs/gallon) is turned into diesel, kerosene, motor oil and other lubricants, which have higher BTUs/gallon and sell for more than gasoline.
Jason
Re: How many are converted to gasoline?
Glenn Madsen, SF Bay Area
>And there are a wide variety of crude oils. Every refinery sets up according to what they are using as feed stock, and what they need to produce. It's not a simple answer.
ADDY Protocol: Not a refinery engineer, but I know a few pretty well.
charlie belden
>You left out Vasoline. Not a coincidence it's a petroleum product - makes getting screwed a tiny bit less "uncomfortable" I've heard.
An insight into commodity prices. *LINK*
Ken Garlock, Collin County Texas
>Hi, good people.
I received an email from my financial manager that gives insight into at least one reason we are paying dearly at the pump.
Please note, this is a testimony on oil and food prices before a congressional committee. It does not address political issues but rather deals with the happenings in the commodity market. It only makes recommendations to the congressional committee to which it was presented.
I do not regard this as a political posting. Some may disagree and request its removal, if so, so be it. I call it educational.
Best regards,
Ken
Commodity prices
LOL
Andy Halterman: Too much work
>Well done.
Andy Halterman
Conny-sewer of good humour in Hendersonville, NC�
Re: An insight into commodity prices.
Gary Evans Tallassee, TN
>Thanks Ken,
That's as good a rundown on what is happening as anything I've seen thus far.
Gary
kenny in indep MO
>I work at the Kansas City Board of Trade, trading wheat futures for a large grain processing firm. This deal started to happen in the grain market about 3 to 4 years ago. Big money(investment funds) bot futures big time. Until then we had a very good market for KC wheat and the other two grain markets, with lots of small traders and cash position traders and a fair amount of large traders. Now we open at 9:30 and wait to close at 1:15, in between I look at wood working sites. Just need to keep this job going for 2 to 3 more years then I can make saw dust all day long. Yes there was a poor year here in the US in the wheat market, but we still had enough bread, etc. But all the things that would move the market up or down have been around for years past and I have never seen a price run up like we have seen in the past two years in the 40 years I have been working in the market. So yes the current run in crude and spillover effect on other markets is nothing more than greed.
Thanks for your time
Kenny in indep
Actually, a barrel is.......
Pete in Holland, MI
>.......a unit of measure. 42 gallons in the petroleum industry, to be specific. The steel container we casually refer to as a barrel is specifically called a steel drum. The wood containers that wine & whiskey are aged in are not barrels, but casks. Casks are made in different sizes, each called names like; butt, Puncheon, Hogshead, Firkin, Pin, etc.
Probably more than you wanted to know.......
Howard Norman
>Thanks Ken, the testimony was certainly educational for me. Has congress started any action in this area?
Fred Davis
>That is true and so is this.
Filling your gas tank in the cool cool morning will give you more gas and better mileage , then filling it in the hot afternoon
Kevin Rabenaldt
>Lynn;
That is interesting to know. Goes to show you not to believe what you hear in the media, that we "sell" the crude to other countries. Is all of the crude from Alaska refined in WA?
Kevin
