ADVERTISE HERE - FREE TRIAL
Router in table saw wing?
Robert Henderson
>I'm moving my shop from a one-car garage (where it was impossible to find the space to work) to my basement (where it is merely very hard to find the space to work).
To make life easier, I'd like to do away with my dedicated router table and put the router insert somewhere else (like in a wing of my table saw).
Would those of you who have had a router mounted in a wing of your table saw please comment on your experiences pro and con.
Suggestions as to how to combine a router table with something else other than a table saw are also welcome.
Re: Router in table saw wing?
>Had one for a while using an add-on to the saw's fence. The additional junk of the fence got to be a pain when using the saw, and I could't reasonably use over-arm dust collection as the boom nixed access to the router. I built my router table on locking wheels (like my other shop machines) and must say that has worked well, especially since I use dust collection in the table. My basement shop is cramped for sure, so I roll out the tool I need, do the operation(s), and then return it to its slot. I think it makes you a more efficient worker because I have to plan out each stage in the process (cutting, jointing, planing, routing, etc.) to keep from spending my time pushing iron around the shop.
I did build my router table (24x36") such that it can serve other functions. It is set as the same height as the table saw and the planer so it can function as an out-feed table as well. When not in use, there is a flush insert installed to keep stuff from falling into the router motor.
mm
Ed in Lawrence, KS
>I have a Craftsman contractor's saw for which I purchased the Craftsman router table made to fit in place of an extension wing. It was a piece of poo - not flat, fence was cheep, etc. I retrenched and purchased an aluminum router plate from Woodpecker that was drilled for my Milwaukee 5625, and used the thick MDF extension wing that originally came with the saw for the table. I used a router plate template from Woodpecker that made cutting the hole in the MDF wing for the new plate pretty slick. As you would expect, the MDF table has sagged a little due to the weight of the 5625, but I've buttressed the table now with some hardwood to remedy this. I like the setup because it doesn't take any additional room from my garage, is flat (now), and I can use my table saw fence for the router table, too. If I ever upgrade my saw, I will seriously think about adding a cast iron router table to it, too.
Ralph Turney
>I've never had a dedicated router table and have always used my table saws right side wing (Delta Contractor and PM66) as my router table and it has only conflicted with each other on the rare occasion. However, I'm looking at a new place with a two car garage and will (hopefully) have tons of space compared to the one car garage that I have now, so this thread got me thinking that maybe I'll build a dedicated router table. But in reality I've been quite happy with sharing the two together until now and just may leave it as is.
Ralph
Ralph Turney
>PS. I have a router table fence that I clamp to my table saw fence that has dust collection and is all wood, so I can chew it up if necessary. I also have a somewhat sealed box underneath that sits on a shelf below the wing that is also used to collect chips and dust.
Richard Jones
>I like mine in the wing. Hardly ever conflicts with using the saw, and I have a separate fence for each. I haven't tried the box surround for the router yet, but plan to do that soon. With a small insert, very little dust/chips goes anywhere except in the shop vac hole in the fence.
I've been very happy with it.
You might try a cabinet shop for a scrap/sink cutout that they toss on the scrap pile.
One nice thing is that if you do it, and don't like it, you sure haven't lost much, right?
Rich
Jim Dillon
>Robert,
I mounted my router in my TS side extension 8 years ago and like the arrangement. As the router fence is removable, it has never interferred with my TS operation. I never got around to building a cabinet to surround the router and probably won't as I built an underneath shelf between the TS and the router to hold my TS fence and other homemade TS fences. I find this arrangement very efficient. Yes, at the time, I looked at the plans for a separate router table cabinet, but efficient space utilization was a higher priority for me. Oh yes, on a couple of occasions, I have even used the TS fence itself as the router fence or to mark the exact location of the router fence. Here are a couple of pics of my router fence (with a nod to Norm Abrams). Hope this helps.
Jim
Pic #2
Jim Dillon
Tom MacGregor
>I received a gift certificate to Sears & bought their "Professional" router & table combo. Total junk. Yard saled the router & installed the top of the router table in the right wing position on my tablesaw. The plywood between the saw & base makes a handy shelf and a four inch hose funneled into the homemade fence doesn't give chips a chance. Works well for me.
Re: Router in table saw wing ?
Chuck in ND
>I built a benchtop router table. When I need it I put it ontop of the tablesaw extension on the right side ( 30" Unifence ) If it ever gets in my way I simply remove it, and the setings on the router table are still there.
>Good Evening Robert,
You can enjoy success either way. I always favored a big table and committed the necessary shop space. My workmate is stored at the ready beneath the right wing of the table saw. I like having a stand alone table which dual functuions as an infeed/outfeed area, as well as a platform for my portable OSS. My router table cabinet houses all my bits in 6 drawers, and houses other router accessories, collets, set up blocks, wrenches, inserts, etc in two other drawers. Lastly, I have an open bottom shelf for tool boxes containing two P+C 690 machines, all bases, and a plunge router. This is true space economy to have all router equipment situated within one mobile cabinet.
George
A.J. Hamler
Here's mine
A.J. Hamler
>This was orginally a Rockler router table that I mounted on a shop-built cabinet. I later removed the top and used the cabinet for something else, and hung the router top on the wall with hinges. I had a small shop then, and it let me swing the table down flat against the wall when not in use.
When we moved to Connecticut and I bought my Jet saw, I cut down the Rockler top to fit between the extension rails and mounted it there. It's been there ever since. Not only is it a convenient place for the router table, but the extension increases my right-side table saw surface for greater support for crosscutting.
My table saw fence does double duty. When using it for the router, I clamp on the router fence. When done, it's back to being a table saw fence again.
A.J.
>I have mine in the Extension of the right extension. I made a router table out of two sink cutouts glue back to back which cancels their tendency to cup. I just recently added a Bear fence and the 30" rails are just right.
My only real complaint is that I use the same fenced or both and it seems every time I get he fence EXACTLY where I need it for the router, I decide I MUST rip something.
I don't have any fancy dust collection. I do have an over the table pick up and that works fairly well, but nothing under the table.
I have been sceming on a down draft table made of an old furnace fan. HMMM? How about a downdraft table with a router in the middle of it? It could also be left running to serve as an ambient air cleaner. Got to make things multi task in a small shop.
David Hay @ Denver
>LOML got me the BenchDog cast iron router table wing that I mounted on the left side of my table saw. So far it's worked great. It rarely is in the way if I need to use the table saw for something else. In addition, I'm able to use the router table by standing in "front" of it, rather than having to reach over, as would be the case if it was on the right side (which is up against a wall, due to space limitations)
David
Robin Corell in Atascadero CA
>I have a jet cabinet saw with a home made phenolic router plate inset into the extension fence. on my old saw I had the same set up and originaly used the table saw fence. I eventualy made a seperate router fence so I could use the router table or the table saw without losing the set up for the other. I will ocasionaly use the table saw fence with a feather board clamped to it in conjunction with the router. sometimes I think my set up is perfect and then there are othertimes when I wish I would have poitioned the router a bit closer to the edge. for production work my set up is great for small detailed joinery stuff I would probably prefer a smaller dedicated table that I didn't have to lean so far over.
I have a big dewalt plunge router and leave it mounted in the table all the time. I have not had significant sag in the 3/4" melamine or the paper reinforced 3/8" phenolic in the 9 years to has been set up in this saw.
Robin
dave in haverford PA
>A great space saver. I have one and added a fence from Wood Haven that clamps to the TS fence. Also added a box dust collector that goes under the table from Woodpecker.
I like mine
Bill Tindall, E.TN
>I milled a Unisaw wing to accommodate a router some 30 years ago. Recently I bought a router table. The wing is a little less convenient than the table.
J D Thomas
>I added mine several years ago. The cabinet underneath was added after the fact since I got REALLY fed up with cleaning up the sawdust. The fence is loosely based on Norm's last one.
The only real problem is when I spread out, which I always do during a project. I invariably have to move a lot of stuff just to get to the router bit. I have no issues with feeding stock from the same side of the table as I would be when using the tablesaw. Others might.
J D Thomas
ThomaStudios
