Temporary wooden ramps?
>I've been asked to build a temporary wooden ramp.
Our church is getting a intern seminarian who has cerebral palsy. She'll be with us for a couple of months this summer. They want her to be up on the dais. Therefore they want a ramp (Father John said "it would be good if it sort of matched the pews and the floor") out of red oak.
The dais is about 6.25" high. As this is a temporary ramp (only used on Sundays for the summer), I wasn't going to do railings. I'm figuring on doing a run of about 60" which would give me a nice easy angle (6 degrees or 84 degrees). I was thinking about making it ~30" wide with a lip. Her powered wheel chair is about 20" wide. I don't know the brand, but 6 degrees seems to be about the minimum incline capability that I've found.
So - do you think 4/4 southern red oak with 5/4 cross braces to the floor at 8" intervals would work (it's also what I have on hand)? Or should I dig up some 8/4 and brace it at 12" intervals?
Re: Temporary wooden ramps?
Steve Schoene
>Your bracing should be more than adequate. 4/4 red oak is pretty stiff. Even with 4/4 braces the 12" interval should be plenty, as long as there is blocking or a middle stringer to keep them from twisting.
The run of 60 " ought to be adequate, though it is not really up to the ADA requirement of a 12:1 slope, which would be a 75" run. With a power chair the critical point is the transition to the floor. If it is too steep, the front wheels will want to lift the drive wheels so they don't touch the ramp. We encountered this recently with a steeper ramp--about 6:1, but I wasn't focusing how shallow the angle would have had to be to avoid the problem.
You don't need a railing, though a "curb" a couple of inches high on the sides can be quite helpful.
John Veerkamp, Western Mo.
>Jl
My brother is in a powered chair. Your 1"/foot rise is easy enough for a powered chair. make sure the edgeing/curb is at least 2" high as these chairs can climb over anything less readily. The ramps at my brothers are 3/4 ply on simple 2X construction lumber. Your oak should be quite adequate for this. I agree no higher rail is necessary.
don't put a high gloss finish because this might be too slippery in the event of water spills.
John
>JL,
I built a short ramp from 4/4 red oak for a friend in a powered chair and so far it's held up for over 15 years (if I'm remembering the date correctly).
As mentioned, I also think it should have side curbs. It would be unfortunate if a slip of the steering control resulted in a tumble.
>I was figuring on a 1:10 slope so it wouldn't interfere too much with the front pew kneelers. I was also going by the ADA accessibility Guidelines which say:
"(3) Special Technical Provisions for Alterations to Existing Buildings and Facilities:
(a) Ramps: Curb ramps and interior or exterior ramps to be constructed on sites or in existing buildings or facilities where space limitations prohibit the use of a 1:12 slope or less may have slopes and rises as follows:
(i) A slope between 1:10 and 1:12 is allowed for a maximum rise of 6 inches (150 mm)." (Close enough to 6.25".)
Good point about the curb. I was planning on a lip of about an inch or so. So I'll make it higher (except on the lowest part).
>Do you think I should put some "sand" in the finish? Or would a satin polyurethane be enough?
Robin Corell in Atascadero CA
>I am curious why this is only a temporary ramp and not a permanent one. At my grandfathers funeral a couple of weeks ago the church had been retro fitted with a ramp (built by my grandfather) and one of the speakers who uses a walker needed to use it to reach the lectern.
Due to a rash of lawsuits many businesses around where I am have made changes to become ADA compliant. I would think having a ramp permanently installed would be a prudent idea.
Robin
Re: Why temporary?
>Nothing is as permanent as a temporary fix to a problem :).
Actually, the Vestry (Elders, Council or whatever) probably just want to see what it is like. We are thinking about building a new sanctuary adjacent to the old one. We are in the exploratory phase (is there enough interest and money) of the process. I'm sure that the new sanctuary will have a ramp up to the dais.
Pete in Holland, MI
>The curb is a good idea, but I would look into something about 3" high. You need to keep the wheels from falling over the edge. To avoid a trip hazzard, some yellow paint/tape along the curb would highlight it for any walkers who venture near the ramp. Sand in the first coat of varnish will leave adequate grit after subsequent coats for tire grip. Transition into the lower floor does need to be pretty seamless. A piece of 3/16" aluminum diamond deck plate, extended from a recess on the ramp to the floor, works well. Not sure how it will be anchored to the floor . Need to think about prevent the chair from getting patially over the top, goosing the throttle, and sliding the ramp backwards, creating a gap. Rubber feet or double-sticky tape may do this.
Good luck !
>satin should be fine for indoors.
John
