"Aircraft" drill bits?
>Also posted on Turning board.
I found a nice book on turning spirals while I was at the Highland Woodworking sale a week or so back. "The Basics of Turning Spirals" by Bill Bowers.
Anyway, he uses surplus aircraft drill bits. One of the nice bits that he has is a large bit with a MT end. It is "hollow" and in the original application had oil pumped through it to cool and lubricate it while cutting metal. He uses it with an air compressor to cool the bit and help get the chips out. He has mounted an air fitting on the side.
I'd really like one or two of these bits. I think that it would work quite nicely for certain drilling applications on the lathe. Anyone have any idea where to find these bits?
TIA
Re: "Aircraft" drill bits?
The usual suspects
>I'd check McMaster-Carr and MSC (Manhattan Supply Co.). They carry every other kind of metalworking and drilling gear. If that fails, you could call Packard Woodworks (see the Marketplace page) and see if they have any idea. I don't have my catalogs handy or I'd look 'em up for you.
Let us know what you find out and how much they charge for bits like that.
Re: Thanks.. I think...
>MSC does have "notched point coolant fed drills". The price is way high. $210 for a 3/4" that is 10" long. Now that I know what to call them. I did do a search on coolant fed drills - that price seems to be a "reasonable" price.
I think I'll try Ebay or a Surplus place.
Jim in Burlington Ont.
The Bit Lady
>bitlady.com
I have a few set's of those smaller bit's used for aircraft assembly. I own a couple of set's of the 20 dollar bag and a few larger spare bits. They will drill hardened steel with ease and cool off in seconds. I'd e-mail them with the specs they always have alot of odd looking stuff at woodworking show's up here.
Re: Google "gun drill"
mike hamilton
John McGaw
>The answer used to be "go to the Boeing surplus store in Kent, WA". Problem is that most of us aren't close to Kent and even if we are I hear that they are closing (or maybe even closed by now). They used to carry a really amazing range of drill bits and such in a wide range of sizes.
Larry in NW Ohio
>JL If you find a surplus store, please post it. I`m always lookinf for a good surplus store. Thanks Larry in Ohio
ScottS
>I googled for "aircraft extension drill bit" and found several results, including a set from Grizzly available through Amazon and a website called "DrillSpot.com". Overall length on the bits it usually 12", but the cutting flutes only cover a small portion of that length in most cases.
If you can't find what you want there, call a local machine shop and ask where they buy their tooling. Expect a drill designed for flow-thru coolant to be expensive...
