>I have a Canon PowerShot S3 that uses SD cards. I transfer pictures to my computer (iMac 20" OSX10.5) via a USB card reader.
My 2gb memory cards work fine in my camera and I can tranfer pics to my computer with no problem. I have a 4gb USB card that works fine in my camera, but when I try to transfer pics to my computer, the card won't read...my computer says there are no pictures on the card. The pics are on the card because I can see them on the camera.
I would almost swear that I was able to transfer to my computer from this card when I first got it, but, since I use several cards on any one trip, I can't be 100% sure.
>Is there a chance that your camera also has built-in memory like my Olympus SP350? If so, then when it can't read the removable card it will default to internal memory. Remove the memory card and turn on the camera and see if the pictures are still shown. If so, then you will need to download them using the camera's download cable.
>I've had a couple of those cards go bad. I don't think the quality is the same across the range of manufacturers. I have since stuck strictly to SanDisk. Some of the others use almost the same SD logo, but print their name smaller.
>"...my computer says there are no pictures on the card..."
What on your computer is telling you that there are no pictures? Windows Explorer, Windows Photo Transfer Wizard or some other software?
When you plug a SD (or other type) card into your reader, it should at least show up as a "Removeable Storage Drive" when you look using Windows Explorer and you should at least be able to see it with an empty folder or something similar.
What you do get when you look at the "drive" using Windows Explorer?
>The card mounts, i.e., it shows up on my screen as a removable storage device, but it shows that the card contains no images. Not true, because I can view the images on my camera screen.
I am almost positive that I have loaded pics from this card to my computer before, but can't now. The other 2 gb SD cards, same brand, work fine on both the camera, just not on the computer.
By the way, It is not true that Macs never fail, just that you don't have to speak seven languages and and have 2 MIT degrees to fix them. A kid I used to have in one of my science classes used to tease me about the Mac on my desk ("Get a REAL computer, Mr. Pack!") We would argue good-naturedly about Mac vs. PC. He graduated, became a computer guru himself and, when my home PC gave me the 'blue screen of death' routine, volunteered to fix it for me. He spent 4 hours trying to reload the OS, doing more geeky typing/coding than I could ever imagine, and ended up as frustrated as I was. It was then that he revealed the truth..."I make my living fixing PCs, Mr. Pack, but I OWN A MAC! You were right!!! If this was a Mac, I could have it working in 10 minutes or less."
>I have experienced the same problem as well using my card reader. I was told that some of the older card readers don't work with the newer higher gigabit cards, like your 4gb one. I too now connect my camera directly with a cable to my computer with no problems. If anything, the transfer rate seems to be faster than with the card reader!
