RubeGoldberg clamping of ash plant stand
Bill Tindall, E.TN
>Some of you have helped with the construction of this plant stand so I thought I would show its assembly. It was not easy to figure out how to clamp it for fitting and assembly. As the legs were compressed the shelves wanted to skid out of position, especially so after it was sanded smooth. I didn't have enough hands to manipulate band clamps. These bandages left from various children's accidents work as handy band clamps. The C-clamps keep the shelves from skidding out of position.
I used the Lee valley asymmetric "bow" for laying out the curves for the bent laminations.
Re: RubeGoldberg clamping of ash plant stand
Engenious
Bill Roland (Mt Juliet, TN)
>Some times you have to think outside the sawdust. What ever works on a project like that is okay in my book.
That's some clever clamping, Bill
Eddie Pacheco; San Jose, Ca.
>I think that line about " bandages left from several children's accidents" is going to scare any of the new parents here....:-)
The plant stand looks like it's going to be pretty nice when done.
>Nice looking!
Tire tubes, from bicycle to 18-wheeler, are a good source for free form clamps. The rubber strips and bands cut from them can be wound as tight as needed around any shape.
Clint
Lee Schierer - McKean, PA
>If I understand the design, the shelves are just glued in place on the legs??? If so, I would be concerned of joint failure over time. Perhaps adding a pocket hole screw under the shelf into each leg would insure long term grip on the legs. The pockets could either be left open or plugged.
Lee
Lee Gordon
Some Magazine
Lee Gordon
>Some magazine must be paying $50-$100 for woodworking tips from readers. You ought to send that one in.
Bill, you're aces
Al Goldstein
agreed
Bill Tindall, E.TN
>That was the basis of my request for information on making pointy headed plugs . And, when all was said and done, wife wanted flat pegs.
The arrangement shown was to get the thing stable enough to drill and install screws. I don't like things moving about when drilling pilot holes. I will often employ 5 min epoxy or CA glue to stick things in place prior to screwing.
Re: agreed
>I would have drilled the holes before assembly from the area inside the legs toward the outside and had the screws holding the shelves to the legs rather than the legs to shelves. (Heads of the screws would have been between the legs.) Having the screws in place would have prevented the sliding along the curve that you saw.
Lee
Ron In Sterling CT
>Bill: It certainly is "coming together" from what I saw a couple of weeks ago when we stopped by. Congratulations -- even Rube would be proud of this clamping arrangement.
Ron
Lee Brubaker
>I had much the same problem with my plant stand. In looking at it I finally decided to dowel the legs to the top & to the spreader shelf. This held everything together enabling the use of strap clamps.
Lee
