Wallnut slices
Nistler
>I want to slice wallnuts for a project.
I have the wallnuts.
How canI slice them SAFELY
I don't want to hand hold a small round anything in the bandsaw.
Wallnut slices
Nistler
Good question -- this might work
>If I had to design my way out of this predicament, I would make a two part sled jig. Each half would have a hemispherical depression in the middle of it, just less than half the diameter of a typical walnut, so that when you put the walnut in there, the two halves don't quite meet.
Next, I would make registration pins for the four corners of the jig to keep the halves in perfect alignment. Then I would mark saw kerf locations at whatever thickness you want your walnut slices. Finally, I would saw through both sections of the jig -- and the walnut -- stopping just after you clear the walnut, so the jig stays intact (but with kerfs now).
If you have a little coal tar to put in the cavities, it makes a good bedding material that will conform to the shape of the shell and offer some added friction to the arrangement to keep the nut from shifting during the cut. It might goop up your blade a bit, though.
Make the jig large enough that your hands can be far away from the blade as you make your cuts. I would also suggest using a relatively fine-tooth blade, maybe 6 - 10 tpi crosscut teeth.
Ellis Walentine, Host
[DISCLAIMER: Any advice offered here, by me or anyone else, is only advisory and in many cases speculative. You are fully responsible for any actions you take in your shop, regardless of whose advice you are following. If it doesn't feel safe, assume it isn't and don't even try it. Even if it does feel safe, take all necessary safety precautions to protect people and property.]
Proof of concept
>I just put together a totally rudimentary version of the jig I described above, without registration pins and just with Forstner bit holes to hold the walnut. I freehand sawed the kerfs with a 4tpi blade, and here is the result. Worked like a champ.
Nice job. Thanks
Parisian, VL
Re: Proof of concept
Grant Smith
>And you could samd them on a belt sander or disk sander once they are cut... Maybe make a similar holding jig or set of jigs such that nuts of different sizes have good support and hold.
Regards,
Grant in Iowa
Down 'n' dirty jig
>When making thin inlays, I used to rout a recess in the face of a block of wood and then put the inlay piece in the recess for sanding on a disc sander or stationary belt sander. If you sand one face flat then turn it over and sand the other face until the belt is in contact with the block, the inlay will have parallel sides and be thickness sanded to the exact depth of the recess. With ivory and other smooth, dense inlay materials, sometimes I used a dab of spit to hold it in the recess for sanding. True confessions.
Re: Wallnut slices
Nistler
>I guess that will work but I want to cut up lots of wallnuts and do not like the idea of cutting up the jig each time
Any other ideas anyone?
The jig is reusable
>I guess I didn't make it clear enough that you don't destroy the jig each time you use it. I should have included a photo of the jig.
With a little more thought, you could devise a way to push it in a controlled fashion, in incremental intervals depending on the thickness of the slices you want. I can imagine a hardboard spline on the underside of the jig riding in parallel grooves in a base board clamped to the saw table.
Lee Gordon
>And you can eat the swarf. :-)
