OT - Compact Fluorescents Revisited *LINK*
Bill Hammond, Oregon Coast
>In a recent discussion on compact fluorescents many expressed their dislike for the lamps. I think I know why.
In a recent discussion on shop lighting a post suggested that 6500K was a good color temp for shop fluorescent lighting, making everything look better and brighter, it got me to thinking... 6500K is rather white and bright.
The local power company handed out some CF lamps and I started comparing them to some that I had and found that the color temp of the CF's from the power company was 2700K. If you are used to white and bright (6500K) then going to a 2700K lamp will be a very dark experience for you. To add insult to the dimness, not all are as bright either. I have nominal 60 W in CF that are 14 W - 900 lumens and 13 W - 720 lumens and the nominal 75 W are 1000 and 1200 lumens. Only one listed the color temp (the ones from the power company). I expect that the others may be even worse.
Therefor I think that the dislike for the CF's is based on expectations generated from marketing information. If you use a CF that has a color temp the same as what you are used to and the lumen output is the same or higher then you would find that CF's are a good replacement. If you buy from a source that is meeting a price point you may have a less than illuminating experience.
All this has to do with how things look and not how fast the light comes on. If you want a fast light use and incandescent, if you want a cheap light for long periods of time then use the CFL's
Also posted on another forum because I really could not remember where the discussion started.
Bill, on the Sunny and bright Oregon Coast
Additional info on color temp. available here.
