Looking for a 3" Carbide SawBlade
WarrenC
>Looking for a 3" Carbide Saw Blade. I can find a 4" and a 2" (for biscuit joiners). any idea where I can look.
thanks
Warren
WarrenC
thanks
Warren
Re: Looking for a 3" Carbide SawBlade
Chuck in ND
>A little more information might help. Like what type of tool it's going on, the arbor size, etc. I can only imagine what the tech support people go through every day, and THEY GET PAID FOR IT !
Warren Chernoff
>I'm building a saw to hollow out the cup portion of a ladle. Arbor size is not important as I can build to fit. Just need to find a source for the blade. A minature table saw blade
Chuck in ND
>Makita makes a couple 3 3/8" blades, but I didn't see any that are carbide tiped.
Chuck in ND
>Warren, I did some more searching and found some 3 3/8" carbide blades. Go to this link and scroll down to the accessories. I hope this helps. http://www.amazon.com/Makita-5090DW-8-Inch-Cordless-Circular/dp/B00004YODY
Warren Chernoff
>Chuck,
thank you
Chuck in ND
>Your welcome Warren. Let us all know how it works out for you.
Re: Core box router bit? Or box router bit?
>Would those work?
Curly Smith
>These might be a bit pricey but:
Solid Carbide Slotting Saws
http://cmitools.com/product/carbide/cbslotting.htm
Solid Carbide Slitting Saws
http://cmitools.com/product/carbide/cbslitting.htm
Then again, these aren't exactly cheap...
The Proxxon mini-saw uses a 3 1/8" blade, replacement blades here:
http://www.mhcrafters.com/servlet/the-1942/Proxxon-36-Teeth-Carbide/Detail?sfs=36768721
3 1/16" plate joiner
http://www.toolstoday.com/searchtt.aspx
Found them
Larry in NW Ohio
>Warren I think I found just what your looking for I found them at SEARS. They are a 3" Carbide saw blade with a .394 arbor and 20 theeth #9 61272, they also had one that was a diamond wheel, I hope this helps. Larry in Ohio
Re: Found them
Warren Chernoff
>Thanks Larry,
Sears, who would have thought?
Re: Found them
Warren Chernoff
>can't get the Sears blades in Canada, bummer
