A case against flauntable dovetails-editorial
Bill Tindall, E.TN
>Earlier someone asked about an aide for learning to make dovetails. I am going to offer some additional advice for someone wanting to learn to make this joint. This advice is based on my observation that this joint would be used more if people were less intimidated by the standards that have evolved for it.
Dovetails are the best way to construct many common projects, for example case work and drawers. Hence, it is not helpful for experienced woodworkers to dissuade apprentices form using this joint. Yet, that is exactly what they do with this fixation on flauntable dovetails.
Dovetails used to be a sign of quality construction. Now it seems, a perfect dovetail has become the entry fee for peer acceptance, and/or a parlor trick to impress an audience.
The dovetail joint has great strength and a far less than perfect dovetail will hold a case or drawer together just fine. In most cases the joint is hidden or at least seldom exposed anyway. So here is my advice:
1. Go to antique stores and see what quality of dovetail is adequate to hold something together for 200 years. Let that be your standard, not the Cosman dovetail executed by someone that makes hundreds of these joints each year in promotions for LN ( this statement is not meant to detract from Cosman or his excellent video.)
2. Force yourself to use dovetails every chance you have. If they hold the piece together you have been successful.
3. Show others how you have successfully held something together with a less than flauntable dovetail so that they may be encouraged to try it. Your less than perfect dovetail may have more positive impact on promoting this useful joint than Cosman.
