Another shed question - site prep? *LINK*
John Weber
>Ok guys, I think I've settled on a pre-built shed/building. It's a lofted barn, 10'x16', it's under 200 sq ft so doesn't require a foundation per code. Typically they level them with blocks directly on the ground. The shed then rests on 4x6 PT skids. It's big, so just wanted to double check site prep. I was planning to level the ground, but wasn't sure if I should bring in any stone or not. Is is worth added a layer of stone under the shed? Better to remove dirt and replace with stone, or simply level the dirt and then add stone? How much if any stone is needed to do the job?
Many thanks, I've added a link one of the company's dealers (not my dealer, but at least shows the barn)
John
http://www.robowash.com/Built-Rite/Built-Rite/Delivery.htm
Re: Another shed question - site prep? *LINK*
Re: Drainage
Dave Mount
>Hi John--
Drainage is the thing I would be thinking about -- you want a site prep that moves rainwater away from the building very effectively. If you don't move the water away, you will have problems guaranteed. Doing this with a load of class 5 followed by compaction would do this nicely unless you're sitting on substantial grade. Drainage is the most important part of any foundation (or lack thereof, in this case). Water is the enemy of all buildings.
My $0.02,
Dave
Re: After Drainage
Glenn Madsen, SF Bay Area
>think vegetation control. At least in my climate. Here in California, I needed the compacted rock for drainage AND plant control. It's important to have only the things grow that my wife WANTS to grow. The rest have to be cleared away.
The other matter to consider is critter control. Packed rock makes for a less attractive alternative for nesting...
>I agree with Dave - drainage is important. I'd hate to have the ground damp all the time under the shed, especially if it is close to the ground on all sides. If the ground is sloped, you can leave it that way and it will drain nicely. They can install the shed on a fair amount of slope with blocks. I think mine is 3.5 blocks in the back corner, on a 1/2 (cap) block just off the ground in the opposite front corner. I put it over grass with no site prep and after a couple of years nothing grows under.
If you want to level and put down gravel, you might need to put drainage pipe under the gravel unless the ground slopes away.
John E in SC
>You didn't mention how unlevel your site is, but unless it's pretty bad, probably no site work is necessary. When we used to do these, we usually put the "low" corner on a 2" block, and leveled from there, so the PT runners were at least 2" off the ground, and the floor of the building at least 6" off. Unless it's really in a hole, probably no need to use gravel for drainage. It can help with grass control / aesthetics, but you might want to think about using some kind of skirting around the building (think mobile home) which closes the gap between the building and the ground. Can do the same thing w/ plants, flower bed edging, etc. Bottom line, I really wouldn't spend much time on site prep unless you've got a really poor site, or just want to. You didn't mention your purpose for the building, but one thing you might want to do is build a ramp up to the door once it's in place - much easier to move rolling equipment in and out vs. a step.
John
John Weber
>I'll try and snap a pic Tuesday. It's fairly flat, but I want part of the shed to sit on an old sidewalk.
Thanks
David Yoho
>I agree with what John E. said. Before Heartland did their part (build the shed), they needed a level place to put it or they would have to use shims to level things. Rather than paying them more or having a sub-par job of leveling with shims, I got the measurements for the spacing of the PT runners for the model I was getting and went to Lowe's and got some 4 x 8 solid blocks. They gave the option for me to buy them myself, which was cheaper, or pay more for them to do it. I laid the recommended number per row and leveled all of them to the low corner.
Afterward, I painted the exterior (it came primed) and built a ramp just to be able to roll things in and out. Mine wasn't off the ground more than 8", so it was no big project.
David
john c. (virginia)
>I've built a few sheds. On the site prep issue, I've found it helpful to clear the under area and lay landscaping fabric cloth, covered by rock, might have been No. 57. It takes a bit more time, but I like this for two reasons. First, the cloth inhibits undergrowth and the rock helps with drainage. I think that lengthens the life of the shed. Second, should you ever need to, it is a lot easier to "use" the space underneath the shed if it isn't plain dirt.
How do you keep it onsite in wind?
Dave Bair, Eaton Rapids, MI
>Don't you have to anchor it solidly to the ground somehow?
David
>My neighbor and another friend put up sheds, both are 24x16 and technically two stories but the ceilings are rather low. The company that builds them set them on blocks and everything was fine for a year or two. Between settling and heaving, we'll be moving both sheds and putting in slabs.
Another neighbor built a 12X20 extension onto his existing workshop. First took out the top soil, brought everything back to grade with crushed stone and crusher run, then a slab. He ran a perimeter drain and the thing is as sound as could be.
FWIW, I'd invest the extra money up front in a slab or at least getting out the loam and then backfilling with stone and a drain as others have suggested.
I should clarify...
John E in SC
>I'm in SC. We don't really have any major movement issues w/ frost heave and such. My vary where you live. But even so, wood frame buildings have at least a little flex, so I still wouldn't think it would be a problem. You might check with the installer who's bringing the building - they would certainly be able to tell you what's needed in your area, if anything.
John
