New planer is sniping at me!
Dan Mitchell
>After much deliberation & consultation, I bought my 1st planer yesterday, a Dewalt 734. My 1st test passes through it have been less than spectacular. Running some fairly straight/flat pine scrap through the machine, pieces sized 18.5 x 2.75 x .875, I'm getting what I'm thinking is a significant amount of snipe. Basically, the 1st & last 2" of the board is coming out thinnner than the rest of the piece, with a very obvious transition at this point. In a worst case, using a dial caliper, one board end was 0.026" thinner at the snipped portion than at the portion just before the sniping. Below is a picture of the worst section, edge and face view. I have set the infeed & outfeed tables as described in the manual, was removing 1/16" at a time & the head was locked. Is this an acceptable amount of snipe? Seems like you'd have to saw the ends off to use the board, 4" off each board's really going to add up over time. This is supposed to be a decent planer. Finish is nice & smooth, apart from the snipe
Thanks for any advice.
Dan
Re: New planer is sniping at me!
>Dan, I have what I think is the previous version of that planer. Mine is a Dewalt and has the two knife cutter head and the knives can be resharpened over and over.
I believe I seldom take a 1/16" cut. I believe I generally take about a 1/32" I would see a 1/16" as being fairly heavy for this machine, but maybe I'm just babying it.
Snip is a problem to a greater or lesser extent with most if not all planers. There are a bunch of things you can do about it. First, adjust the machine. I believe the infeed and outfeed tables should be just a little high. Also, It helps if you lift the board as you feed it in an out.
You can also feed boards side by side with one leading. The leading one gets the snipe, but the rest of them don't get it until the last one gets it on the trailing end. You can run long scraps through as sacrificial parts to avoid it. You can attach "rails" to pieces either with glue or double stick tape and let them stick out front and rear to avoid the snip on the good piece.
I would suggest you should cut the pieces four inches too long and dress them and then trim the snip off the ends. I find that if I leave the ragged ends on the pieces of lumber until after I dress them I can cut them off I can kill two birds with one stone. (I have lumber that I cut and dried myself, and there is sometimes splitting and checking at the ends.
If the snip is very slight, a pass through a sander like a Performax will take it off. Even hand sanding or sanding with a ROS will do it. (Another excuse to buy a new tool.)
Another approach is to cut pieces after the lumber is dressed. In other words, where the lumber is nice and flat, dress and eight foot piece and then cut it into four two's. That way you have only two snips rather than eight.
>A couple of thoughts (for what they are worth as I have a DW735, not the DW734).
How about more support on the outfeed side? Do you have a roller platform/table that you could put on that side? I usually end up supporting small boards with my hand and supporting the big boards with my roller table.
Dale Lenz
Dale Lenz
>Dan,
Try shimming the front of the infeed table with some playing cards, 3-4 on either side, then do the same thing on the rear of the outfeed table. What you want is sort of a "V" shape. There are other methods to solve your problem, but the method above is pretty simple. I always try to support the out coming board with a little upward pressure when I have time/think about it.
Dan Mitchell
>Barry - Thanks for the great reply. I just ran some additional sizes of material through, to vary things a bit, including a bit of 2x6 & a 20" piece of cedar 4x4. I tried various lifting techniques, etc; looks like I'll need to practice that a bit. So far, I've only run soft woods, I can imagine this might also be a factor.
I'll say one thing, planing the cedar sure smells nice ;-)
My main concern was there was an issue with this particular machine. If this is just the nature of the beasts & you have to work-around, I can live with that. I'm thinking if these had 4 rollers (2 in & 2 out) the wood would be held flat much more effectively. But then, they wouldn't cost ~$350, I guess. Again, other than the snipe, the finish is great. It is a 3 blade machine. I couldn't believe how smooth & pretty that rough piece of cedar came out!
BTW sorry to hear about your accident. I hope no one was injured. I second those who recommend Edmunds. Awhile back, my wife was working in California for a time while I was living in Ohio (long story). She totaled her Prizm (great way to buy American & Japanese at the same time, since it's a COROLLA with a CHEVY bow-tie!) & I negotiated her purchase of a new Subaru wagon entirely over the phone, substantially below sticker. All she had to do was go in, sign the paper work & drive away. Yahoo Autos (http://autos.yahoo.com/) is a similar site.
Dan
Dan Mitchell
>JL-So far the pieces I've been running for practice have been short enough that they don't make it off the tables. I have read that roller stands are required for longer bits. I have one, guess I'll have to buy another!
Thanks for the reply,
Dan
Dan Mitchell
>Dale-I was surprised to see that the inboard edge of each outer table is actually below the inner table (portion right below the blades/rollers). The manual then shows the outboard edge of each table being adjusted so that it is at the level of the inner table, giving a slight "V" configuration, as you say. I would have thought the ideal would have been for all 3 areas (infeed, middle section, outfeed) to have been perfectly level with each other. Out of the box, a straight edge spanning both tables was about 1/8" above the inner section, so I did set the tables down a bit using the adjustments provided. Didn't appear to make a difference, though.
Dan
pecker
>I only want to mention that .02" is a lot. My Ryobi lunchbox planer gives about .005" at either end. It took a couple tries to get it adjusted this close, and that still seems too much to me. But I live with it.
Auxillary Table
Marvin Horn
>Used to have the 733 which had the sheet metal infeed and outfeed tables. I adjusted the tables slightly high (0.020") at the ends and used an auxillary table. Bought a 4' melimine covered particleboard shelf, ripped it to fit through the planer and stuck on a strip of wood on the bottom to catch on the planers infeed table so it wouldn't feed thru with the wood being planed. There are numerous examples some plain like mine some very elaborate to be found if you search the archives or google for them.
Whenever snipe reappeared it was always quickly eliminated by adjusting the ends of the feed table.
Go to Badger Pond Articles.... *LINK*
Tim Greif - West of Chicago
>The link below will take you to the Badger Pond articles. In particular, to one called "Planer Setup" by Dan Barber. Very good discussion of how to eliminate snipe on a planer. I'm not convinced you can ever totally eliminate it, but you certainly can reduce it to the point of being acceptable. I used the technique in the article to tune mine.
I've not tried the auxiliary feed table but the pic below is one example someone posted long ago.
good luck
Planer Setup
Jim Dillon
>Dan,
I built the planer bed like Tim's picture. It works very well and I keep it on the planer full-time. I made it from MDF with two plywood cleats on the underside at the ends. I also keep it well waxed. It also helps to lift the board up slightly during infeed and when the board is nearly finished. Also, if I have a long enough board (and can remember to do so), I allow for several inches at each end to cut off - just in case: sanding out significant snipe in a hard wood can be difficult. I also take a minimum cut (1/64) at first to see if I get any tear-out then adjust accordingly. IIRC on my Dewalt planer one full turn of the handle is 1/16 inch. I almost never take that much off at one time (especially on the finishing pass) although I sure would like to do so to speed things up 8-). Overall, I have been very pleased with my Dewalt planer. If you do decide to make the planer bed, I would round the corner edges to prevent gouging your hip as you walk by. Hope this helps.
Jim
Your head is moving!
Lee Schierer - McKean, PA
>It sounds to me like your planer head is moving as the board exits the planer. If you look undeer the hood, you'll probably find that the infeed roller is exactly 2" from the centerline of the cutter head. When the trailing edge of the board leaves the infeed roller the cutter head is dropping. This would indicate a problem with you head locking mechanism. Check you owners manual to see if there is any adjustment on the head locking.
Lee
Hal Smith
>I've had a 734 for some 4 yrs. and have had virtually no snipe problem from right out of the box. The infeed and outfeed tables form a slight "V" as someone suggested earlier. I feed the material in at an angle instead of straight in - an old trick that I'm surprised someone hasn't mentioned earlier in this thread. And I definitely support the boards both on the infeed and outfeed sides. One thing that comes to mind is the (slight) possibility that the indexing system for your knives is off a hair. Good luck. Hal
Dan Mitchell
>Yeah the amount I'm getting seems like a lot to me. It's easy to see & even easier to feel.
Dan
Dan Mitchell
>Thanks for the replies, I guess I'm going to have to walk through all the possible adjustment issues, head pressure, blades, etc.
In a perfect world, expensive machinery would work properly out of the box.
I've seen the added beds, also read a review of the 733 here (which I think is the same as the 734, but w/o the 3rd blade). I'm a bit confused. Intuitively, I'd expect providing a supportive, long, flat bed absolutely parallel to the rollers/cutter would be best. But this seems counter to the "v-ing" of the infeed/outfeed tables/lifting up the outboard end of the work piece approach. ???
Thanks again,
Dan
Jim Dillon
>Dan,
I'm sure no expert here, but I think the very slight "V" between the infield and outfield tables simulates "lifting" of the board IF the board was fairly short, say 24 inches or so. But, in my mind, a longer board would tend to tip down on both the infield and outfield sides increasing the liklihood of snipe - thus the need to slightly lift the longer board. Anyway, I hope you get it sorted out.
Jim
