>I blew the controller for my GE DC treadmill motor and need a TDA1085C integrated circuit controller to see if that will rejuvinate my board. There appears to be plenty of information on them but they also appear to be obsolete. Does anyone have a clue as to where I might get one?
>The "CG" version of that IC is available at Mouser Electronics for $1.68. I don't know if you can make that work or not but the plain "C" version is declared as obsolete.
>When I saw the post title, I jumped right in. Oops, you didn't need one that old, I went through tech school in '57-'58, before ICs were thought of (just as the first transistors were coming out). All Army communications equipment were still tube type then.
>Ha! That's what I thought, someone needs some tube help. I must be a little younger than you: my first real electronics project was a regenerative tube-amplified shortwave radio receiver along about '59 or '60. (I was 9 or 10 years old then) Winding the coils was the most fun.
>I just got a working Dynaco SCA-35 at a yard sale for $2.00. It seemed too cool to pass up, but I've never delt with tubes before. I've been trying to figure out how to restore/upgrade/mod the thing with online info., but if you can suggest a good BASIC reference or point me towards someone within spittin' distance of Central Vermont that could help I'd appreciate it.
>That is my problem, George. I attended Holabird Signal Depot in or near Baltimore, MD in 1943. Had training in radio maintenance and repair and managed to do a lot of field diagnosis for the Division radio people during combat. Usually could get to the root of a problem by figuring out what the resistance of a circuit ought to be and then measuring what it actually was. By subtracting the one from the other and then looking up the resistance of the components it wasn't too hard to figure out which componant was bad. Try doing that today, Hah.
I had to ask to find out what an IC is. I got this controller not more than six years ago, I think, and it is already obsolete. Trouble is there are very few old electronics guys today. Most of the new guys know nothing of the old circuits which are as much Greek to them as modern circuitry is to me.
>Well if had been some of you young folks I would have thought of tubes also. But for some reason when I noticed that the poster was Don Henthorn I figured that it had to be a solid state device problem. I started out with tube circuits in the early 50's and started working in the semiconductor industry in 1955. Everything was germanium based in those days. Silicon came a few years later.
Do you mean a reference to answer "how does a vacuum tube work", "how does a circuit work", "how does a tube circuit work", "how can I find a bad component", or "how can I learn enough to work on my SCA-35"?
Is there a problem with the amp, i.e., does it work but is noisy? Do you have a circuit diagram?
I don't know ANYONE who is specifically an expert on tube circuits these days.
>i remember working on amps and radio's in the 30's And working on these tell Tv's came out All tube's Than went onto working on them Than hybread's came out Still working on those Than when solid state came out Still work on them Tell about 25 yrs ago I been retired So Didn't miss out on anything On repairing Repaired some of the stuff that was built real good Now thro it away and buy a new one That is the way it is done now days Cost to much to fix part's ect And most dont know how to repair Just replace it I dont do no repair any more All wood working now
>The chip you are looking at is more like the brain of the DC drive than the muscle behind it. On a DC drive like this, it is more likely that the switching transistors are what fails more than the controller, especially if they are FETs. Obviously the IC is pretty cheap, and if it is easily replaced without de-soldering, then great, replace it. However, I would take a closer look at the transistors. You'll find the transistors bolted to a heat sink of some type.
>Oh, I just looked at the spec sheet for the controller. It states that it is intended for Triac control, so instead of being power transistors, they are probably Triacs. They will look about the same with 3 terminals and will be bolted to a heat sink. The Triac should be easier to find, and you might even be able to find them at a good Radio Shack.
Rick, you may be right about the Triacs but my problem arose because of old age a and a devistating senior moment. I plugged the 120 power lead to the wrong terminals and fried something. I just thought I would start with the IC. I'll look tomorrow and see if I can find the Triacs.
