THE WOODRAT IS BACK!
Shopsmith sander attachment
Parisian, VL
>I'm usually on the quiet side, but tonight I'm looking for some help locating a (actually and assortment is desired) small sanding drum(s) for an older Shopsmith power-head (IIRC that's what it is called) Anyway dimensions are 3" long by about 2-9/32 inch diameter. Diameter is a strange size, but it fits over a hard rubber wheel with a metal mandrel in the center that bolts to the motor shaft.
Any help will be appreciated.
Regards,
Victor - In warm and humid Houston
Re: Shopsmith sander attachment
Joseph Mulherin, Sr.
>Hello, Vic, I too have the Shopsmith and all of the attachments you mentioned. Go to the Shopsmith website and go into the catalog/ sanding section and you will find the mandrel and the entire assortment of sanding drums available.
Thanks
Victor Parisian
