Garage door threshold....glue type?
Virgil Johnson, Versailles KY
>I bought a rubber garage door threshold for the 16'shop door and it did not come with adhesive. The tech line was clueless and said I needed to call another tech line. I'm thinking of using a polyurethane construction adhesive. Anybody put one of these down? ....that stayed down :-)
Re: Garage door threshold....glue type?
Larry in NW Ohio
>Virgil I don`t recall ever seeing a glue type of door seal. The only ones I see and ever got were the one that nailed to the bottom of the door. From your messageit sounded like you want to put in on the floor, is this right? Larry i Ohio
Dale Lenz
Dale Lenz
>Purchased one, guessing 1994, water ran under the door, purchased house Dec. 93. Worked GREAT and glue is still working. Clear glue type came with door seal. Glue came in a squeeze tube, "plain-Jane" type of label/tube. Have you tried an Internet search?
Good luck,
Dale
>I should have been more specific. the rubber threshold glues to the floor. About once every three months we get a driving rain that leaves puddles in the floor.
Dave Bair, Eaton Rapids, MI
>I'm no expert, but I've always used clear silicone caulk/adhesive on thresholds with 100% success. It's flexible when cured and adheres well to a variety of substrates.
Larry Clinton At Frankfort (Central)., Indiana
>I installed one about 3 years ago for the same reason you are. The rubber threshold came with the glue in an unbranded toothpaste type tube. I wish I could help you more, the glue was NOT a clear silicone, but has held up very well so far.
