200+ woodworking book reviews
Delta 34-444 Contractors table saw outfeed table
Chuck in ND
>Yesterday I ordered a Delta 50-390 outfeed table support. I stumbled across one new in the box in ebay, but it sold before I could get to it. Well after doing some looking around I find out that Delta had discontinued them and they are hard to find. I did eventually find another one new in the box on the internet and it should be here on Friday. I never knew such a accessory from Delta existed for this table saw. It fits the 34-444 and 34-445. Mine is a 34-445X. So anyway, I have a question for anyone who has this setup. Being that it's a Delta contractors saw, and Delta made the accessory, I'm hopeing that it will also work when the saw blade is fully tilted. Does anyone have any experience with this accessory ?
Re: Delta 34-444 Contractors table saw outfeed table
Blade tilting shouldn't matter
Dustmaker Mike
>to the out feed table unless maybe a support gets in the way. From the ones I have seen they bolt to the fence rail on the back of the saw for support and a set of legs on the other side. So I would say there should not be a problem. But I am just going by the ones I have seen and I am not sure I have seen the one you are mentioning.
Does it look like this? ____*Link*
Rod Peterson -- Ormond Beach
>I recently added a page to my Norm's Tools site on his outfeed table. It seems he's had two over the years. The one at the bottom has the closest model number to yours (but it's a Biesemeyer—a Delta subsidiary).
I thought people might like to see one.
Rod
Re: Does it look like this? ____*Link*
Chuck in ND
>I know it's not the best picture, but thats what they show. Suposedly it folds also, all that comes in the kit are the brackets, I have to make my own board. I realize it doesn't extend out very far, but it's better than the short distance that I currently have from the blade to the end of the table now. And it should work out good because my shop is my double stall garage also, I remove the motor and wheel the saw on it's mobile base up against the wall at the end of the day. Also I have a Unifence so there is no back rail to get in the way of the table.
Tony - Memphis
>Well, I'm no help. I have that exact setup, but I can't remember the last time I moved my blade, so I'm not sure if it matters or not. There was something I did a while back - or wanted to do - and the extension was in the way. Just can't remember what it was, darnit. The extension has been really nice to have though. I bought the supports on clearance at a local ww place. The top I made is a little warped, so I need to make a new one, but I have been lazy. Now that I think about it, I'm pretty sure I was trying to tilt the blade and the supports got in the way.
Tony
Chuck in ND
>Tony, I was afraid of that. If I remember correctly the motor does swing up pretty far on a 45 degree bevel. I may have to look at shiming the support on one side out from the cabinet to get enough clearance if thats possible. Strange that no one at Delta took the time to check it, or get it right. But then again, look at the poor excuse of a dust hood they made for these saws. The new 36-979 saw looks better, atleast it's a funnel shape and not just a shallow tray with a hole in the center. I still don't like the fact that it points straight down though.
Rick Haverstock
>Hello Chuck,
Not sure if mine is the same model number (and it's not anywhere on the sheet metal)but from the pic is sure looks like the same thing. Rest easy tonight as I can assure you that it will let you go to a 45 degree tilt with no problems. I added an additional table section (outfeed to the outfeed)for sheetgoods work with a simple frame and braces and a melamine top. I saw the brackets at a local woodworking show and bought them immediately as it was the best solution to those of us still using the Jet-Lock fence (mine actually locks up square after a lot of fiddling). I'd add a pic but can't seem to find any on the computer right now. Hit me back if you need one.
Rick Haverstock
Chuck in ND
>Hey Rick, thanks for the post. Thats really great to hear. I really kind of dreded the thought of haveing to take the extra time to modify something without butchering it. Does yours fold up ? or down ? it didn't say in the desription.
>I have a Rockwell Delta saw that is a 34-338 and its about thirty six years old. The original motor on it burned up years ago and I replaced it with one from Dayton. I noticed that the motor comes up to barely below the level of the top when the saw is at forty five degrees. That's perfectly OK in day to day use, but when I considered adding an extension table that would be about an inch and a half thick I realized the motor would hit it. My solution was to route out the cavity in the underside of the table for the motor to recess in.
This may not have been necessary with the factory motor, but I don't know. You could tell by cranking your saw over to forty five and putting a straight edge on the table to see how much clearance you would have.
Chuck in ND
>Barry, I've seen people haveing to cut a hole in the top of the table board, which isn't to big of a deal. My concern was the brackets. If you look at the picture closely you will notice the brackets comeing out the sides of the saw are fairly deep.
Rick Haverstock
>Chuck,
Almost ashamed to say that I never, ever fold it down. The recommended size top section(saw width and about 12-14" deep) lifts up to unlock the brackets, slides back, and the whole shooting match then folds down, clearing the motor, Per my other post, I added an extension to the small section pinning the two together with some butt hinges I had on hand. Added a couple of folding legs for the rearmost section and I had plenty of table for the dredded MDF and other sheet goods. I'd take some pics for you, but am currently remodeling the other portion of the basement and the shop is now my storage area and too junked up to be captured on film. And I take back my opening statement. I built an 8 foot dingy a few years back and did have to fold up the back section to work on the boat.
Rick Haverstock
Chuck in ND
>Rick, the reason I ask about how the table folds is at the end of the day I take the motor off and scoot the backside of the table saw up against the wall so I can park vehicles. With the mobile base sticking out I probably have about 6 inches between the saw and the wall. And just for reference I think I paid a pretty good penny for the extension I'm sure compared to what you did, but I had to pay shipping also. The total came to around $65, but it was the last one I could find new in the box anywhere. Retail on them was $45.
Re: Delta 53-390 outfeed support has arrived
Chuck in ND
>I opened the box and looked things over a bit, and I'm impressed with how thick the metal is that the brackets are made of. I then grabed the manual and noticed that it says it is made for certain Delta Contractors saws that are equipped with stamped steel extension wings only. I may have a problem with that, the left side on my saw is a stamped steel wing, the right side is a extension table for the 30" Unifence. I may have to find or order another stamped steel wing and cut down the right side extension table to get it to work. Tomarrow I will go out and look things over on the saw, it's a little late in the day now for me to start such a project. Overall I think this is going to be a nice addition to the saw once I get it done. You know, nothing ever seems to be easy or without costing more money to make it work. I'll add more posts as the progress goes.
Chuck in ND
>Rick, you were correct. Yesterday I had a chance to install the brackets and cut a board for the top, I'm not done with the board yet though, I'd like to edge it with a rabbited 2" X 3" then Fornica it, after that I still need to cut the miter slots. I checked the motor for clearance and there is about a 1/2" between the motor and the top, The same goes for between the motor and the bracket on the side.
Chuck in ND
>Here are the contents of the Delta 50-390 outfeed support.
Tony - Memphis
>Looks like the same setup I got. I'm not sure what I did, but when I installed the homemade extension board onto the brackets, I ended up with a hump in it that I had to correct. I may make a new one (someday) and install it with bolts with countersunl holes to give it some room to move around a little. I may have just used screws, can't remember. I still think my motor hits it when I roll it over, but its been so long, I can't recall. I can't lower mine because I made the top such that it won't, so I'm not familiar with how well that works or not. I've been daydreaming about upgrading to a PM2000 saw, but its hard to justify. This saw has been a good one for around 10 or 11 years now. I don't cut anything real thick or heavy, mostly 4/4 stuff and I don't depend on the TS for joinery. Kind of sentimental now too - I've built many a project with that saw.
Tony
Chuck in ND
>Tony, I'm kind of in the same boat as you are in, I bought my saw new 13 years ago and have absolutely no complaints with it at all, It's seen ALOT of use over those years and continues to run strong. I'm not really sold on some of the Hybrids at the difference in price I'd have to pay if I sold this saw, and a cabinet saw just seems like overkill for what I do, plus right now my budget is very tight. Someone else had mentioned that their board had warped on the outfeed table also, thats why I want to add the rabbited 2" X 3" around the perimeter or some kind of stiffener, angle iron, etc. I still haven't decided what would be rigid enough, but not overly heavy.
Chuck in ND
>Well folks this is how far I've gotten so far. I've decided to construct it like a couter top. The two wide boards in the middle are for suport should I ever decide to cut miter slots into the top, I rarely ever use the miter gauge, but if I do the extension table is very easy to remove, so I'm still undecided weather I want to cut the slots, but the suport will be there if I decide to. The half circle cut into one of the suports is for clearance on one of the capacitors of the motor when the blade is fully tilted. I need to edge band it with 1/2" quartersawn oak, Formica the top, then sand the underside and edges and put a couple coats of poly on the exposed wood to lessen the cances of warping from humidity. It's all comeing along, slowly but surely.
Chuck in ND
Chuck in ND
Stop it Chuck!
Tony - Memphis
>Ok, now you've gotten me to feeling guilty that my table looks so bad and I can't tilt all the way and now I'm gonna have to go home and redo mine. Thanks!
Re: Sorry Tony
Chuck in ND
>Now I'm almost afraid to show it when I get it done. (-:
No, please do!
Tony - Memphis
>I'm not too proud to steal all of your effort and copy it!
I was looking at mine this weekend and it is pretty rough! It is the first flat surface I get to when I enter the shop, so I lay stuff there, its a nice flat painting/staining surface, etc. May be time for a new one. I did replace the cheeks on my wood vise and even made some slip in cheeks for non wood holding this weekend. I'm building a dressing table and I was afraid my vice cheeks would mess up my drawer material I was working on, so it was time.
Tony
Re: Here ya go Tony
Chuck in ND
>I finally got the outfeed table done.
Re: Another pic
Chuck in ND
