Cutting thin strips on table or band saw
Gary Smyth
>I once saw a set up for safe cutting of identical, long (three foot) 1/8" strips on a power saw. I even found a video on youtube, but somehow I'm missing the article (or was it a video) that showed how to cut strips. I need the strips tens at a time. I thought about building a gang saw, but while I need a lot of the strips it's easier if I do it with what I have, if I can locate the jig. The strips are generally no more than 1 1/2" wide on a table saw and 8" wide on a band saw. For the band saw the guide was more than a drift pin or canted fence.
I'm looking for a specific device from the web, or Woodsmith, Fine Woodworking, etc., or even jig books. I have a lot of research materials, but I keep missing the one jig for which I am searching. If I remember correctly it used both a featherboard and clear, thick plexiglas. On that I may be wrong. Please list any places you know of or the source for a thin cut jig. I'll run it down if whoever provides an reply cannot post the information.
Thanks
Re: Cutting thin strips on table or band saw
Charles Neil on youtube
Wayne Carson
>http://www.youtube.com/watch?v=FullQWi2ZwM
hope it helps
Re: Cutting thin strips on table or band saw *LINK*
David Yoho
>Gary, I use this method and it works great. Below is a link to a video by Charles Neil on cutting thin strips.
David
Charles Neil Video on cuttin thin strips
Wayne and David
Gary Smyth
>Thank you for that information. I did view that video and it is not the one I'm looking for. I have used that technique but with it you really ought to stop when the board gets to an inch. That's all well and good, but the one I'm looking for was safer with the thin starting piece as it rode over-covered it going through the blade
Re: Cutting thin strips - Woodworker's Journal
North of the Border
>How about this tip?
http://tinyurl.com/2ch8lr
Re: Wayne and David
woodhack
>Here is a jig from wood magazine... maybe this is the one you were
thinking of.
http://dgroups.woodmagazine.com/n/pfx/forum.aspx?nav=messages&webtag=topshoptip&tid=1283
JoeW in Detroit, MI
>Try Woodsmith 120 page 27 or 119 page 27
Stuart Johnson
>I saw one example that uses the fence set to the thickness of strip. Make a push stick out of 3/4" plywood 3 or 4 inches wide and maybe 8 inches long with a handle on top. On the bottom cut a 1/4" dado across the width about an inch from the back end. Glue in a piece of that is maybe 1/8 proud. Set your fence to the width of your strip and run it through with the push stick against the fence. A grove will be cut through the push stick and you just run the next strip.
I have used this method but I'll leave it to others to say if it is safe or not.
Re: One more source - FW
North of the Border
>I recall reading an article in Fine Woodworking (a few years ago) which featured a bookmark maker. He used a shopmade system to cut the thin bookmarks made of cherry, etc. in a very accurate and repetitive manner. He sold thousands (or tens of thousands?) of his bookmarks each year. Does anyone have the collection of FW magazines and point out the issue?
What I like about it....
David Yoho
>Gary, what I think is real important with this method and what I like is the thin cut-off strip falls away on the waste side of the blade. I have never liked having those pieces cut between the fence and the blade. It provides too much opportunity for the piece to bind and shoot back, burn from contact with the blade, or sometimes cut a gouge into the strip.
David
Found both references. Thank you
Gary Smyth
>What I was searcing for is similar. I can take it from there. The push block I remember is clear plex and extends over the blade. I believe I can make your suggestions work.
Thanks
Gary Smyth
>What you mention seems to be in the right time frame. I used to pull articles from Fine Woodworking and that is perhaps where I remember it. If anyone remembers or has the CD I'd like to try to find it again just to check.
Got it. Thanks.
Gary Smyth
Bill H. in Jersey
>Rockler has what they call a "Thin Rip Tablesaw Jig" that I have had good luck with,its easy to use and I get very consistent results.
Re: Wayne and David
Larry in NW Ohio
>I tried this site a couple of times and it does`t seem to want to appear on my computer. Can someone send it to me or post it here. Thank You Larry in Ohio
Gary, I found it on FW website!
North of the Border
>FW # 158
http://tinyurl.com/ys5h5n
Don't see a jig in that article
Don in Northern Arizona
>If it is #158 page 74-75. The guy who sells to L.L.Bean, etc. He uses 2 bandsaws and 2 drum sanders to make his thin stock. He also watches TV while scroll sawing and has all of his fingers.
Don
>It seems to me this would be a good place for a vacuum setup.
I would want to set up a jig that was a strip about four inches wide with a pusher strip on the following end. I would make that the same thickness as my strips and put a piece or pieces on the top that would hold the strip down. The jig would be about as long as my strips.
First I would try the jig as described. Set your saw fence so that the jig is the thickness of the strip form the blade. Insert the stock for the strips into the side of the jig and feed both through the saw.
if the strips tried to escape or burned, I would consider adding a vacuum port or ports to the sled or jig particularly at the trailing end. A suction port could hold the strip tight to the sled until it cleared the blade. A valve could turn the vacuum on and off.
Something like this seems to me to be what you would want to make hundreds of strips. The thing about moving the fence each time appears good, but impractical to do for hundreds of times. With the jig and fences remaining in the same position, you could feed stock much faster and the strips would be consistent.
