moldy wood
moldy wood
moldy wood
David
>I've been moving my shop from the garage into my barn and discovered that a pile, perhaps 2-300 bf, of rough cut sugar maple is now moldy. Mostly it's the black powdery stuff that can be brushed off. Given the problems associated with getting rid of mold in buildings that got wet, I'm wondering if I should keep this stuff out of the new barn for fear of contaminating everything.
Thanks!
Re: moldy wood
Re: moldy wood
Malcolm Timbers
>Run it through the planer and then keep it dry and it should be no problem. After all, spalted maple is just mouldy old wood.
Re: moldy wood
Re: moldy wood
Ed Mulligan, Cape Cod
>I would 'paint' them with a strong solution of laundry bleach, let them dry overnight, then store them. Wear old clothes :)
I once had some weird green mold growing on mdf in a damp basement. I wiped the mold with a soaking wet rag of strong bleach and moved the mdf to a dry location. End of problem.
Ed
Re: moldy wood
agreed
Bill Tindall, E.TN
>This should be an effective treatment. Not to worry about contaminating other things. These spores are, and were, everywhere already.
Where ever this wood was at is too wet a location to store lumber.
Re: moldy wood
Warning
John Veerkamp
>Be sure to wear a proper face mask. Many people are highly allergic to mold spores and some are toxic. Why take a chance?
Re: moldy wood
Re: moldy wood
r payne
>Bleach will certainly be a good surface treatment. It only needs to be 10% household bleach. It may or may not penetrate which may or may not be a problem as some molds will grow into the wood and some will stay on the surface. Mold spores are pretty well everywhere so contaiminating other stuff has already happened. Keeping stuff dry will keep the mold from growing.
What I would do is get a spray bottle and fill it with a 10% bleach solution. Spary the wood just to the point of run off to ensure coverage (anything more is wasting the bleach). Let the wood dry. You can stack it stickered as if you were air drying green wood and
Keep it dry.
ron
Re: moldy wood
Re: moldy wood
David
>Thanks for all the responses and caution. You've allayed my fears. I made the mistake of trying to store the wood in my garage which usually isn't that wet but there was little air circulation.
