Dust Gorilla stand question
David G. Sparks
>I'm hoping to get a Dust Gorilla soon. Can anyone tell me the advantage to having the floor stand as opposed to the wall mount? I know assembly is probably easier with the floor stand, but it costs $218 more. Is it worth it? Thanks for your help.
Re: Dust Gorilla stand question
>I have no direct experience with a Dust Gorilla, because I don't won one, but I do have a home made Air Cleaner and a Delta dust collector.
The DC is in a little shed/closet attached to the rear wall of my shop and it just sits on the floor. The Air Cleaner is bolted to the ceiling just inside the common wall with the closet. My bedroom is directly above both. If my son works in the shop while I am in the bedroom, the dust collector is barely audible, but the Air clean drives me nuts. Its the direct connection/vibration/noise.
So I would suggest that the floor stand would be less likely to turn a wall into a giant speaker/sounding board.
Rick in Colgate, Wi
>I'm going to look at a Dust Gorilla this morning and hopefully buy it. The owners manual says that if you attach the wall brackets to concrete or block to place pieces of 2x4 between the wall and brackets to dampen vibration.
Mine will be wall mounted on concrete block. You could always add the stand later if you found it necessary.
>I have the Super Dust Gorilla. I have block walls in my basement shop, so I got the regular stand. I considered the floor stand for a minute or two, but decided against it.
Consider the placement of your intended purchase.
My SDG is more or less in the corner of my shop. It was "interesting" hoisting the cone up to the stand and then putting the "barrel" up on top. Fastening the two sections together was also an "interesting" exercise. I was thankful that I had the 2 x 4s on the wall! The worst part was putting the motor and impeller housing on top of the barrel and cone - make sure you have a good friend when you do this - you can't do it alone.
The floor stand would have made the assembly much easier. I could have assembled it out in the open and then gotten it into the corner. Is it really worth the money? I don't know. If you have a block wall and don't intend on putting it right in the corner, I'd say no. It depends on the placement.
YMMV. My $0.02.
David G. Sparks
>I hadn't considered being able to move the collector if I used the floor stand. That gives me more options as well as making assembly easier/safer. I'll consider that. Thanks!
On the stand!!!
Scott in Montana
>Mine is mounted in absolutely the worst placement; on the wall and in the corner. It is amplified not only by the megaphone effect that the corner provides, but dust collector also causes the whole wall to resonate. In my shop you wear hearing protection not due to the machinery noise... but due to the dust collector roar. It works great, but if I had it all to do over again, it would be on the stand, outdoors in a little shed.
Also, wall mounting it is definitely a two man job. Stand mounting may be as well.
Scott
Bill Hylton
>I've got the Gorilla on the stand in my basement shop. I've got 2" to 3" less than 8' clearance from floor to the underside of the joists, and mostly because of that, I have a duct routed between the dust barrel and the wall. Oneida's rep wouldn't sanction shifting the collector on the wall bracket away from the wall to make space for the dust, though in retrospect, I probably could have.
Still, the stand is a nice rack for hanging hoses, extension cords, etc.
Doesn't make assembly of the cyclone any easier. You still have to hoist the motor and impeller overhead. I did do it myself, but it warn't easy.
Bill
What I did with my Oneida...
Grant in Iowa
>I ordered it with the standard angle brackets.
The brackets must be mounted further apart than standard 16" stud spacing, so you can't mount them directly to the wall.
Oneida balances their impellers so well that the unit doesn't vibrate at all, so no worries about transferring sound to the structure.
To install it on the wall, I mounted a piece of 3/4" plywood about 35"wide x 48" tall which spanned three studs and the top 4' of the wall. This allowed me to lag bolt the plywood to the top plate in the wall, and also three studs.
Then, following the Oneida instructions for positioning, I mounted the angles to the plywood using more lag bolts. This proved to be a sturdy mounting system.
You'll need help lifting the motor and impeller/ housing assembly onto the angle brackets, but it will sit there while you install the retaining bolts.
By the way, be prepared to be impressed at the build quality of this unit...I was!
Regards,
Grant in Iowa
Larry in NW Ohio
>What do you mean"You can`t do it yourself". I have a 3 HP industrial unit and I did it all myself, twice. I used a couple of small block and tackle, which made it easier. Larry in Ohio
