>A customer has asked me to build a table using old bowling alley lanes for the top. I'm in SE Wisconsin and will go 100 miles or so to get them. Does any one know where such a thing could be found? Thanks in advance.
>I'd suggest you head over to the message forums at bowltech.com. They have classified ads that may point you in the direction of a center that's closing, and from which you may be able to procure a lane or two.
Do keep in mind that many centers have switched from wood lanes to synthetic, and many continue to do so. The process frequently entails removal of the entire wood lane bed. You might try calling a few centers in your area to see if they plan on switching (I don't call it upgrading...I hate bowling on synthetics!) this summer, and whether or not the old beds might be up for grabs. I went bowling one Sunday last summer when a center was in the process of switching, and they had a huge dumpster full of chopped up lanes. Kills me that I didn't have the means of taking any of that lumber with me. :(
>I'm sure one or more of the actual denizens will check in on this thread, but I recall a couple of them (seems to me, Tommy, Jennifer, and Dominic each tried some—but if my memory isn't any better than it was on year long DST, probably not) had some experience with old bowling alley material and it was not as good as they would have wished. Apparently they price those things by the weight of fasteners put in them. Think lots of tenacious nails or staples. Almost certainly more work than worth it.
>I used bowling lanes for a couple of workbench tops. Here are some things to know:
Most of the lanes are usually fir or something like that. Only the approach areas are maple.
The strips of wood are side-nailed together everywhere! You cannot cut anywhere without cutting through nails. They are otherwise poorly joined and will sag appart unless you support the section of lane.
They usually have a layer of asphaltic material on the bottoms of the lane slabs.
I bought the slabs for a song. But in the end they were way too much work. You might want to consider that.
Tom
The urethane coating on top is a nightmare to remove. I used a commercial floor sander and it was seriously no fun.
>I use one for a workbench top. Mine has some inlaid round black plastic pin markers. As other have said, this one is full of nails. Also, the wood has separated a little leaving narrow gaps between some of the boards. It works great for a workbench top for pounding and drilling, but I would hate to have to build something nice from it.
If I had to make a nice table from a piece of bowling lane, I think I would get new maple and glue it up to look like a bowling lane. Could even route out recesses and install the plastic pin or lane markers.
>On a traditional wood lane, the first ~15 feet of the lane itself is maple...after that, it changes to pine (you can see the finger joint where it transitions). At the pin deck, it switches back to maple.
The idea of fabricating your own "lane" is a good one. As an FYI, there are 39 boards on a lane, each a shade over 1" wide. I believe the rangefinder dots and arrows were usually inlaid walnut, but some lanes may have used plastic.
>Everything said about bowling lanes is absolutely right on the money. I just finishing up playing with a 7 foot piece that I making into an outfeed/assembly table
I was able to use an old but sharp bench chisel to strip off a lot of the urethane finish in sheets. Then belt sanded with 36, 50, 80, & 120 (4 hours later...). I originally took off the iron rails from the underside but since it's not glued, just fastened with big spiral-cut nails, it bowed in the middle so back on went the rails. And it is pine.
Given that I got this and another piece (11') for free, and that the base is made from 3x4 pine dunnage from my barn siding and left over 2xs from other jobs, (honestly, I'm really not that cheap) and that I don't plan to beat on it too hard, it's fine. Not my material of choice however.
After reading all the cons of bowling alley I will say that I have 2 sections 8' long for sale. I live more that 100 miles from you but if you are interested let me know.
>....I coulda directed you to a Minnasota bowling Alley going out of biz and selling the lanes DIRT CHEAP. 100 bocks for a 19' chunk of 2" maple is cheap.
Anyways....I know its too late on the story above, but I lucked out years ago and got in at the tail end of a local bowling alley going out salw where I picked up (2) 8' x 42" wide lanes of 2" pine and
>SE Wisconsin is lousy with these things. Unfortunately, I cannot recall the name of the guy, but there is a salvage place outside of MKE that has these things for sale. Call you local bowling center and ask.
