Drill press manual
Drill press manual
Drill press manual
Justin Szeliga
>I've got an old Sears Drill press I bought used, w/a set of mortising bits. I was trying to get the chuck off the other day & install the mortising chuck, & couldn't get it unscrew or tap off. Any sources for a manual or a site dealing w/drill press maintenance? I tried Sears, can't find any links to owners manuals.
Thanks
Justin
Re: Drill press manual
edward mccormack
>Try here
http://www.owwm.com/
Robin Corell in Atascadero, CA
>The OWWM site is in the process of a data base change over. once the change is compleate and the site is back online it definately will be good source for old craftsman manuals available for free as PDF files.
Robin
Larry in NW Ohio
>Justin Do you have a serial or model # or maybe better could you post a pic. What kind of belt does it have, if it has a very narrow 3/16" I could send you copies of mine. Larry in Ohio
