>Not sure if this is OT-ish or not. I have an old bachelor chest where the veneer on the drawer front is so dried out that it is coming up in shards. Basically if you accidentally hit a drawer at an angle, you're guaranteed to get a nasty splinter. I'm guessing that I'd need to totally remove the old veneer, looks like burl walnut, and apply new, but am wondering if there is any way to stabilize what is there?
>The answer is "it depends." Chances are good that the glue is shot, and no amount of heroics will fix it, with one possible exception -- heat. I would first take a sharpened palette knife or exacto blade and see how difficult it is to pry up more of the burl veneer. If it comes up easily and cleanly, the bond is gone, presumably due to moisture or age. You can try ironing it, ramping up the heat by degrees (pun intended) to see if that improves the adhesion. If not, I'd consider replacing the veneer. If the border veneer is flaking off, odds are that the main face veneer isn't much better attached, so you need to grapple with that, too.
If all you want to do is repair this one drawer face, you can chisel back past the splintered areas and cut a patch of similar or matching veneer to fit the cleared area. Don't forget to scrape all the glue off the substrate in this area. Patches can be easy or difficult to match to the old veneer, depending on their shape. The easiest way is to make the patch rectangular. To hide the glue line, it's good to bevel the edges of the old and new veneer so the new stuff overlays and forms a tight scarf-type joint at these interfaces. Glue and clamp it, using wax paper and a little flat block of MDF or something. Scrape/sand the patch flush to the adjacent veneer and seal it with a thin coat of shellac. Finish as necessary to match into the old surface appearance -- stain, padding lacquer, shellac, whatever. I don't think I would use an oil finish if the old glue is suspect. The oil might make matters worse. Anyhow, try it before you commit to it.
