I'm trying to create a return address label that I can use with all my mailings.
Does anyone know whether Word saves the label file after you create one under the Tools\Envelopes and Labels command? I'd like to be able to go back and print the same label as needed.
After entering the return label data and defining the type of label sheet (Avery number, etc), click "New Document" and a Word document will be created populated with your label data. You can save this document for reprinting.
BTW, I haven't used this feature. What I have done for years is simply make a page full of my return address to fit my favorite label sheet. To test the sheet before wasting a page of labels, I print on a piece of plain paper and hold it and a blank label sheet up to the light to see if everything lines up.
>I'm not sure about how Office 2007 functions but I know the XP version and previous versions will retain the most recently created return address if you use the envelope/labels tool. My guess is that the 2007 version will be consistent, but this is a Microsoft product so your mileage may vary.
>I use a Mac, but I think it will work the same. Go to MS Word/Preferences and enter the appropriate information under user information. You can then go to Tools/Envelope and click the use my address button. Works for labels also.
