WS3000
WS3000
WS3000
Larry in NW Ohio
>Just a couple of quick questions. I`m planning on getting the WS3000 sometime soon. I`d like to know can a person use this to sharpen lawnmower blades with it? Also I got 3 new chisles from Sears a couple of weeks ago, yes I know they are inexpensive, but they were on sale and I will not use them very much. What is the best angle to have on them? The angle that is on them seems to be pretty blunt. Should I change them to a sharper angle so they cut better? Also do you put different angles on them for different woods? Thanks Larry in Ohio
Re: WS3000
Re: WS3000
>>...I`d like to know can a person use this to
I haven't used the work sharp, but from what I know about lawnmower blades that sharpener doesn't seem appropriate. Typically lawnmower blades need a lot of material removed to fix cutting edges damaged by rocks, etc. I think this is best done with a rough grinder, perhaps a hand-held side angle grinder. It is generally recommended by blade makers to finish sharpening with a big file.
Re: WS3000
Will not work on lawn mower blades - get a grinder
Chicago Bob
Re: WS3000
Bart Goldberg
Re: WS3000
Bart Goldberg
>If I'm in a hurry, I'll use a belt sander to sharpen my blades. Other times, i just use a file.
