>I checked out Joe Woodworker's site and built an air compressor powered vacuum press from his kit. I haven't used it yet other than to play with it. Looks like it will meet my needs just fine.
I don't know what vacuum press David Mark's has, but I purchased the basic kit from VacuPress. If you don't want to take the time to build your own, I would recommend the unit I purchased: Its the Compact 100 and I've been very happy with it.
>Tony - how did you make your smaller bag, and where did you get the material? I have found spotty information here and there, but lost the book (read: lent to a friend) I had with detailed instructions on bag making. The bags in the instruction book were made from clear plastic upholstery protector used in furniture and sold by the yard.
But the book or similar articles can't be found. Sure would appreciate some details or some pointers.
>... was a real Rube Goldberg affair, back in about 1978 or so. It wasn't even a bag, per se, but rather a sheet of upholstery vinyl that I got for a song at an upholsterer's shop. The vacuum came from a used 1/2-hp cow milker pump with about a 5 gallon tank that I picked up at a local farm auction for five bucks. I drilled a hole in the middle of my 4x8 assembly table (the top was flakeboard) for a 3/8" nipple and connected the milker to it with some 1/4" copper tubing I had salvaged from an old refrigerator. To create a seal, I used double-faced foam tape, stuck to the table around the piece I was veneering and just pressed the edge of the sheet onto it. It wasn't 100% airtight, but it worked well enough to get the job done.
My point is, if you only need a quick setup to get you through a job, you don't need to spend a lot of time or money. I'll bet you can still find those milkers around for cheap.
>Man, I'm really showing my age. The only automatic milkers we had on the farm was the ones at the end of my arms! But we weren't into dairy farming, just a few milkers for us and the cats.
