Oneida dust collection system - to buy or not
Dean Campa
>I am looking at purchasing the Oneida 2.5 hp or 3.0 hp Gorilla dust collector for my homeshop. I would appreciate any comments anyone has about this system or if there is another product i should also consider. Thanks
Re: Oneida dust collection system - to buy or not
my experience- positive
Bill Tindall, E.TN
>I thought a central dust collection was an extravagance. In a temporary fit of spendthriftness I bought the Oneida system. Bruised butt kicking it that I didn't own one from the start. Shop stays cleaner and house less dusty. I let Oneida design it and they saved me money. Don't but the expensive pipe as it is unnecessary. I have accidentally deadheaded my system several times and not collapsed the standard thicker snap together pipe.
While the system doesn't catch everything it gets most and makes cleaning up the rest easy.
>I have the "Super Dust Gorilla" cyclone. I also bought the snap lock ducting from Oneida.
The 2 hp system (which I have) is enough to run ~70 ft. of 6" ducting and numerous drops. I planned my own system as Oneida had discontinued the planning for my size system unless you paid ~$100.
My only regret is I didn't fork out the extra money for a metal drum. The system collects dust from numerous tools quite well - including sanding dust from my lathe and routing "chips" from my router table.
Steve Roxberg
>I have the 2hp Super and have been very happy with it. E-mail me if you would like photos of my install or some install tips.
I would also recommend using spiral pipe for all the runs.
Andrew Nistock
>Dean,
By all means go for it. I bought the 3 hp dust gorilla over a year ago and I am happy as can be. They designed it for free and we went to the factory to pick it up. Everything was waiting for us and the company was very good to deal with. Went together without a hitch and it does a great job. Plenty of suction for a 15 inch planer or anything else I want to run. Not only that but it is made in the USA with good switches and mine has a baldor motor which in my experience is the best. I would opt for the 3 hp over the 2 hp. Good luck
Cream of the crop. Better than sliced bread.
Art Silva
why do you recommend spiral pipe?
Bill Tindall, E.TN
Jesse Cloud
>I have had the 2 HP version for about 3 years now - absolutely no complaints! If you don't have super long runs (mine is about 50 ft) or run several machines at once (two is my max) you might not need 3 HP.
Two small notes of caution - get some help when you install it - its heavy! and check the dust barrel regularly - its a mess when it fills up and sends dust to the filter. DAMHIKT!
Jay St. Peter - Southern, MD
>No complaints from me. I think Oneida is the one to get.
Jay
Larry in NW Ohio
>I have had my 3HP Industrial Cyclone for over 4 years now, and works like a charm if not better. Had a little trouble at first with the motor overheating, so they sent me an upgraded motor. They couldn`t figure out why it was overheating, but over time I think it is the S&D PVC pipe I use. According to what I read on Bill Pentz`s site is that air flows thru it better than steel. At least that is all I could come up with. But know I have a couple of fans I scarfed out of a couple of microwaves blowing on it. It does not leave much of anything on the floor. I would sure buy one again. Larry in Ohio
Re: why do you recommend spiral pipe?
Steven Roxberg
>Because you don't get the static build up like you do with PVC. I'm not worried about an explosion, but don't like the hair on my head or arms standing out. It can be grounded, and pvc can't.
Just a personal preference and it can be purchased fairly cheap if you shop it.
"snap together" a cheaper choice
Bill Tindall, E.TN
>Oneida recommended to me to use the snap together (stove pipe) heavy gauge pipe they sell. It works fine. I have an elbow of this stuff at the top of our commercial sized planer that used to see many thousand bdft of lumber go through it per year. It is shows insignificant wear. And as I noted I have accidentally dead headed my 2 HP system several times and not collapsed it.
