>Does anyone know where I could find really thin plastic sheets?
The thinnest stuff I've found is 0.7 MIL plastic drop-cloth sheets at HomeDEpot/Lowes. They have the typical 6MIL, 3MIL, 1MIL and 0.7MIL but I'm looking for something like 0.5 or 0.3 MIL.
Anyone have any ideas where to look? We need pieces that are approximately 3' square, so plastic bags, etc aren't large enough. We looked into dry-cleaner bags, but so far haven't found anything large enough.
We need to make extremely lightweight parachutes for a science project. We've used 0.7MIL in the past sucessfully, but am looking to find something even thinner/lighter if possible.
>I thought Dry cleaners bags were a half mill. Or is it 1.5 mill?
How about stretching some? Don't know how you could do it, but if you stretch polyethylene it stretches easily at first and then hits a limit and then breaks. My understanding is that it the limit it is stronger than steel of the same thickness. And that is how they make racing sails out of it (I think, babble, babble). Perhaps you could make a balloon out of a dry cleaners bag and inflate it. A science project with in a science project.
The local grocery store has bags of poly that are very thin. Perhaps you could contact the manufacturer of those or cleaners bags for some that was even thinner.
>Mylar comes in very thin sheets. Attaching the string to this materil may be a problem though. Maybe scotch tape at each point where you need a hole for the string.
Re: OT - Looking for very thin plastic sheeting *LINK*
Jim Dillon
>Mark,
Wild shot here, but what about those thin, cheap plastic paint drop cloths? Here is a link to a 0.5 mil thick one on Amazon, but the local Borg/hardware/paint store might have something similar. I also found reference to a plastic sheet(?) of some sort 0.5 mil thick linked to an Autobody store (http://www.azautobodysupply.com/fistplsh12x4.html). It was under a category called "masking film". Hope this helps.
>That looks like a good source. I'll browse around their website this evening and see if I can find something. We'd like to try Mylar if we could get our hands on some.
We found that scotch-tape works okay, but those little little self-sticking hole-reinforment things that you buy in the school supply store for 3-hole loose-leaf paper works much better.
>I think the dry-cleaner bags must be 0.5 MIL or less, because they are thinner than the 0.7 MIL sheeting we got. That would be a good thing to try if we could get the size we need, but haven't really been able to find it the right size.
The grocery bags material would also be great, but again, unless we could find the manufacturer of the bags we can't find pieces large enough. Joining them is really out of the question. And larger bags from stores tend to be thicker material.
>actually). Contact my former employer. Ask to be connected to the Metallizing Plant. Tell them you would like some 75 gauge or 60 gauge metallized OPP scrap. They run tens of thousands of feet of the stuff. They can give you some of the test scrap off of the metallizer. It shouldn't cost you anything.
>... Mark, and that is one of those paint drop cloths that are two layers. Several years ago I was doing some interior painting. I bought these flimsy (and I do mean FLIMSY) drop cloths that were a nonwoven absorbant fabric on one side and a very thin transparent plastic on the other side. The fabric sucked up any paint spills and the plastic prevented the paint from going all the way through. They were pretty worthless because they so easily tore, but if the plastic layer is only attached along the edge (I really don't remember), maybe you can cut the edge off and you are left with a thin piece of plastic that might work. Just a thought. Sounds like a neat project. Of course, there is always ripstop nylon... 8-).
>I have two diferent kinds and out of curiosity I threw a mic on them both. he type used for clean room suits is .0049" and the other type I have is .0038".
>Mark, You might want to compare those parachutes to real ones. Something tells me that 3' square will not do much to slow your decent. :-) I might muffle your scream though?
I have some Aluminized mylar here that is too thin to measure with my digital calipers (the good Mitutoyo set that reads to .0005"). Four layers of it measured 0.0005" so counting wrinkles and the air between, so I'm guessing it's close to 0.0001".
It is thin enough that I can read my computer monitor through it (if the text is not too small!)
To get some? Just visit your friendly neighborhood superconducting magnet company and beg a piece! A local company here used it as high efficiency insulation for superconducting magnets that were cooled with liquid helium. They wrapped many layers of this stuff around the magnet coils, dewars, and piping.
About 20 years ago a friend of mine who worked there salvaged a bunch of this when they tore down one large setup and he brought me a garbage bag full. I remember stretching pieces out in my living room and most were 15' or so long. I'm not sure about the width of what I have left.
The stuff is such a good insulator you can wrap a bit around your arm and feel the heat immediately. My friend tried sandwiching a few sheets between cloth sheets and the resulting blanket was so hot it was unusable. This looks very shiny like aluminum foil. The piece I have in my hand at the moment is over one square foot in area and weighs about one gram on my triple-beam balance scale. I dropped it from about 7' just now and it took almost 10 seconds to reach the ground.
The stuff is very strong except just like other thin mylar, it will tear easily once a tear begins at a cut or nick.
If you want a piece or two, let me know and I'll dig out what I have left and see if it is big enough. If not, I could probably call the local company and see if they would give me a few feet off their roll. I suspect it only costs pennies per square yard.
BTW, I see they make this stuff in much thinner sheets - look at the weight of a square meter of some of these:
