Veritas - Innovation in Tools
Picture fram glass
Picture fram glass
Picture fram glass
Larry in NW Ohio
>I just finished a picture display uvit for my daughter and now I need some glass for it. I was told to get some glare-free glass. I have never heard of the stuff. Does anyone know where to get this kind of glass? Thank You Larry in Ohio
Re: Picture fram glass
>It's not worth it. It costs more and dulls the appearance of whatever is behind it. Just use regular 1/8" clear glass.
Clint
Re: Picture fram glass *LINK*
Jim Dillon
>Larry,
Most any place that does picture frames will carry non-glare glass and they probably will cut it for you. Basically it is regular glass with a slightly matte surface to cut down on the glare. If you aren't near a store, here is a link to a widely used source. They will also custom-cut the glass. And you can buy acrylic "glass" as well. But then you will have to pay shipping 8-(. Try to find a local place first. Hope this helps.
Jim
Light Impressions
Gene Gauss
>If it's something you don't want to have deteriorate with time, consider using "preservation glass" that cuts the ultraviolet light that would cause deterioration of the pigments in the picture, and actually of the paper itself.
Dale Lenz
Re: Check out your local glass shop
Dale Lenz
John McGaw
>Glare-free glass is over-rated IMHO. Sure, there are situations where it is appropriate but most pictures will do fine behind normal single-strength glass which you can obtain virtually anywhere. Glare-free obscures fine details (with some people's portraits this might be worth the price of admission) but if the artwork is going to be mounted more than about 2-mat-boards thickness from the glass the loss becomes quite noticeable. Also, some people complain that the surface of glare-free is difficult to clean but I've never had the problem with finger prints that some people seem to have had.
Baker Glass . . .
steve mackay
>Don't know if they're " nation wide " but they do eveything from windsheilds to showers. They don't mind my little goofy projects coming in now and then. I think it breaks up their day from the ordinary. And no matter how out of square I am ( to their ammusment ! ) they cut to fit. They WANT my money !
Buy UV glass
Bill Turpin in WNC mountains
>I recommend UV resistant glass. My nephew owns an upscale frame shop in Charlotte, NC. He had a movie bill poster that spent about nine months close to the store's front east facing window. It was framed with normal glass. It had pastel, muted colors when I saw it for the first time. He had a duplicate that had seen no sun exposure. It had vibrant colors similar to a macaw parrot from South America. The price difference is well worth it.
Re: good anti-glare glass
Denny
>Larry,
It's true that common anti-glare glass is slightly textured and obscures details, but there is an excellent anti-glare glass that I've used, Tru Vue Reflection Control glass. It has a non-glare chemical coating that works like magic. It isn't cheap, but it works very well.
Denny
Jeff Bartelt
>Larry,
We have designed, manufactured, and sold display cases for years. To be honest, I agree with most of the posts here...save your money and get regular 1/8" single strength glass (or double strength if it's larger than about 20x20 or you are worried about strength). We have rarely used glare-resistant glass...only if requested by the customer. It's much more expensive and does take away detail from the contents inside. UV glass is acceptable but it is also expensive and is only necessary if your contents are of great value.
Check out our website for pictures of our display cases if you want an idea of what yours may look like. All are shown with regular glass. Take care!
Jeff
http://www.classicalhardwood.com
