How to check a 45?
How to check a 45?
How to check a 45?
jeff
>Stupid question maybe, but..
How do you check a 45.
It's easy to check the zccuracy of a right angle square, but I've always wondered about my 45's.
Jeff
Re: How to check a 45?
Jason Roehl in Lafayette, IN
>First, open the slide slightly and make sure there is no round in the chamber...oh, wait, wrong "45".
Some of the most accurate 45� triangles available are plastic drafting triangles. Hobby/craft stores often have them.
Jason
Re: TAKE AIM-SQUEEZE TRIGGER. BANG!
Bill Roland (Mt Juliet,TN)
>Use a forty five try square? Or a combination square that has a forty five angle on it?
Or, cut two, put them together and test them with a ninety degree square. This would tend to double the error or cancel it, depending on how you cut and assembled them.
use a marking knife and
Robin Corell in Atascadero Ca
>draw a line on a board at 90*, it is best to have the head near the end to make the line as long as possible. Now slide the head to the other end and make a line at 45* that intersects the 90* lineas far away from the edge of the board as the square will allow. now using a rule or a set of trammels measure from the edge of the board to where the lines intersect and this should equal the distance between the two lines along the edge of the board.
Robin
