Help with old Delta lathe
VLParisian
>Today I acquired an old Delta lathe ( catalogue # 46-612P Ser # 93010505) It is missing the tool rest. Any thoughts on where I might purchase a replacement? Anybody know anything about this model? All I know is that the previous owner bought it at a school auction some years ago and never used it.
Victor - in cold and wet Houston
Re: Help with old Delta lathe
Robin Corell in Atascadero Ca
>I'm pretty sure most of the delta lathes and all of the 46 series all use the same tool rest. I broke one years ago and they had them in stock at a local delta dealer. It was a newer style but worked fine. The also pop up on ebay regularly and ocasionaly go for enough below retail to pay for shipping.
Tool rest or Banjo?
Phil Joines Krum, Tx
>Tool rests are available at a bunch of places. The banjo is a bit harder but they are available. If you can't find a Delta look at one for a Nova DVR or 3K from Woodcraft. I used one when I added riser blocks to LOML's Delta Industrial. Just needed to make a new clamp plate for it.
Thanks guys. I knew I could count on the board
VLParisian
Mike L, Orange County, CA
>You can get Delta tool rests and banjo from Amazon.com. You may have to dig around their site to find the banjo (at least I had to) but it's there. Good luck.
Mike
