Help for Cutting Coves on Table Saw
Kelly Handwerk
>I am trying to find information on cutting coves on the table saw. I would like to know can I get the same shape cove with a 7in cove cutting blade as a 10 in blade? I know the 7 in will leave the molding with less scratches, but will the cove be the same "shape"? Can I get the same shape with the 7in blade if I change the angle that the wood meets the blade? Any Help.
Re: Help for Cutting Coves on Table Saw
Tony - Memphis
>It won't be exactly the same, but you could get close. I've written a couple of programs that calculate the profile based on input of the blade diameter and the angle of attack. I'm not sure how I can distribute the latest version as it is in VB .net and I haven't tried to pass it on to anyone. The old one is on this web site somewhere, but it doesn't allow input of the blade diam. Let me see if I can figure out how to distribute the new version. It draws pictures, so you could compare them.
Why does the 7" blade leave less scratches?
Tony
David Yoho
I'm no math wiz like many of the folks here but my experience says you should be able to get what you're after with the smaller diameter blade and the right angle.
That said, if you're making a normal shaped coved crown molding, there's another way to cut the cove that's easier and yields a smoother cut than doing it on the tablesaw. Several of the router bit manufacturers now sell horizontal crown molding bits in various sizes. I have one from Infinity Bits but Eagle America has them too. The cut is very smooth and reduces the need for all that sanding afterward. You'll want to use it in a variable speed router of at least 2 HP or better. My Porter Cable 892 handles them just fine.
David
Tony - Memphis
>Well, I just ran a couple of test runs...
10" blade, 30� tilt, 1" high -- cut width is 3.001"
To get the same cut width, I had to change the fence angle to 38�.
When I printed the templates out, it was hard to see much difference. So, it looks like you can get mighty darn close.
My program is very crude. I have neve polished it up for public consumption. Maybe I should work on that.
Tony
Tony - Memphis
>Yeah, I tried a bit from MSC and it did a great job except that it left a small "line" in the middle. The bit was defective and they gave me a refund. I never tried another bit as I got the job done and fixed the piece. But, the technique worked just fine and it felt much safer than the ts method. I'd try that again. Those bits are a "bit" expensive though.
I got to use that CMT Lonnie Bird cutter one time (at Lonnie Bird's school, no less) and it was very nice. Too expensive for me, but a real nice tool.
Tony
No and No
Why they are different
Robin Corell in Atascadero Ca
>It probably sounds improbable but when you cut a cove on a table saw with a round blade the resulting cut is actually elliptical. If you are having a hard time wraping your brain around how that is possible just take a length of dowel and cut it at a very acute angle and look at the shape of the end. For most coves the elliptical nature of the cut is not noticeable and I only mention it to illustrate that every angle results in a different ellipse and that if you change the diameter of the blade you again will generate a different ellipse. By adjusting the angle on two diferent diameter blades to cut the same width and depth cove you would infact still be generating two different ellipses. Will you notice the diference? probably not.
I have found that 10" blade with a flat ground tooth will cut a cleaner cove than a blade with an alternate angle tooth grind and that a thicker blade will cut cleaner than a narrow kerf blade. I am curious to know what a 7" cove cutting blade is.
Robin
PS
Tony - Memphis
>Oh, you said 7" COVE CUTTING BLADE! I missed that. Is that the Lonnie Bird/CMT cutter thing? Yeah, those are nice. It did leave a very smooth surface.
Tony
Re: PS
Randy Stukenberg
>I have one of those and like it a lot. One trick I found tho... make your last cut very miniscule - just crank the blade up a hair to get a smooth cut. Otherwise it will leave grooves like a regular saw blade.
-Randy
