>I have seen rigs similar to this, powered in much the same way, over 20 years ago in Michigan (LP). I have seen them powered by a JD A or B by belt from the pulley. No matter how a buzz rig is powered, it is inherently unsafe. Nevertheless they were, and may still be common, an heavily used to cut firewood. I have used one myself. Much that was done in farming was and is unsafe - but there are "few" accidents considering that. (And I know of a few doozies that happened.)
>There are/were a lot of them around Michigan in the rural areas. We still use one at our tractor show to buzz up the slab wood from the saw mill into firewood for the steam engine.
Many were built up from parts laying around. Some were store bought. Most received their power from the PTO pulley of a tractor. Later ones mounted on a more contemporary tractor's 3-point hitch and were coupled to the rear PTO for power.
Buzz saw blades are different than saw mill blades. They have a negative rake to the teeth so the blade doesn't draw itself into the wood when cutting.
The easy ones to build were ones where a tilting table tilted the wood into the blade. The better, but more complicated designs, tilted the blade into the stationary wood.
Have seen ones like the one you show here built up on an old car/truck chassis. Often, they were built to park the vehicle, and jack up one side of the rear axle so its tire bears against a pulley on the buzz saw arbor, and let the differential shift all the power to the blade, while the other wheel was blocked in place.
Yup, they can be dangerous, but many things are when not in the hands of a confident operator. They were quite the time saving device before a chain saw came along.
>...were the favored chasis to build those on around here when I was a kid. They usually just had the hood and windshield left with a wooden box and a burlap sack to sit on. Saw a couple built on the front end of farm tractors with a belt drive off the belt pulley. They usually had a platform on hinges that you laid the 'slab' on. Then you just pushed the platform with the slab on it into the blade, back and forth, as some brave soul held the end of the short piece being cut off.
>The interesting thing with these buzz rigs is that we were all very, very careful - we had to be. Well, there were those who were not careful about anything dealing with equipment - we all knew them - and the lack of hands, fingers, or arms showed it.
>Yup, I've used one powered by a tractor back in the 50's - belt drive from the tractor PTO wheel. I really didn't think it was too unsafe, didn't know any better, and much of the equipment used in industry and farms was as bad or worse. My best friend's father had a sawmill made from a 47 or 48 Oldsmobile. He cut and sawed several acres of large oak trees using it and a front loader on a tractor. I helped my friend convert a garage to a family room in his house using 2" X 12"'s X 16' air dried oak joists sawn on the Old's rig. The boards were about as accurate as I get from todays sawmill's. I didn't see the unit but my friend said it had a powered carrier/slide to move the log through the mill. Don't know how he made it, but obviously it worked quite well.
>These truck mounted buzz saw rigs normally didn't do too much traveling, other than around the farm or near by farms. Twas definitely a purpose built machine with frugal engineering in mind.
>I remember these also. I don't remember how they were powered,but I never saw one that the saw was pulled into the wood: they had a hinged table to push the wood into the saw.
The ones that I remembered had two safety features; A car tire (probably a truck tire) cut in two and mounted over the exposed top of the saw blade, and one had a ramp that was placed under the blade so the the cut-off fell onto it and slid away from the saw.
