This must be my night for questions. I need to make some handle for some old tools that were once my grand-father-in-law's. Many of the tools are missing handles, some of them simply need to have a little better handle. I know how to turn the handle, it is getting the tool to stay in the handle that I am having a problem with.
>I've not done it myself, but witnessed a demo a few years back. In a nutshell, you turn the handle, and at the top, drill a hole smaller than your tool's tang, and cut a slot through this hole. Then you get a coarse-threaded brass compression nut that you thread on and glue with the tool in place. You can even turn the flats off the nut ahead of time if you wish for a cleaner look.
>I assume you are talking about tools like screwdrivers, chisels, etc.
My preferred method is to make the hole in the handle slightly undersized and force the handle onto the tang. Tapered tangs require a stepped hole. I do all of my turning tools this way.
A second option is to use epoxy.
A third option is to use an undersized hole and to heat the tang red hot, then drive it into the hole. Makes lots of smoke, but the tool will be firmly bonded to the handle. I did this a couple of times and had to chisel the handle off when I wanted to replace the handle.
>Rob I've probably made 75 to 100 tool handles over the years. I use 2 methods to fasten the tool to the handle.
One method is the old blacksmith way. I drill a hole slightly undersized. Then I heat the tip of the tang to almost red hot. I hold the tool in a vise and then drive the handle on. The heat enlarges the hole as you drive the tool in. I've had tools fastened this way for years without coming loose. It works really well with square or retangular tangs.
The other method is to drill a hole the correct size or even a hair larger and then use epoxy to hold it in place. You may have a problem with the epoxy pushing the tool back out by hydraulic action. To solve this I drill a tiny hole through the outside near the bottom of the hole. the excess epoxy is force out the hole. You can wipe it off with alcohol and the epoxy will fill the hole.
>For tanged chisels I use various sizes of copper pipe cut into 5/6 -1" lengths depending on the diameter. The tubing should be a bit loose as the tang will make it fit tighter. I drill a stepped hole and then use a combination of an 1/8" mortise lock chisel and a mori nomi to make the hole tapered with square corners to match the tang.
A mori nomi is a Japanese chisel used to clean up the sides and bottoms of mortises. It excels at turning a round hole into a square one. The mortise chisel is used for the very bottom where the mori nomi won't reach. If you have a chance to pick one up it is invaluable for fitting tangs tools to their handles.
I fit the handle till the flange at the end of the tang is about 1/8" when �dry� fit with my hands. I then climb the tool onto the handle by striking the end of the handle with a wooden mallet until the flange is snug to the handle. If everything is fit perfectly the ferrule becomes snug just before the tool is snug to the handle and the last 1/32" takes as many strikes as the first 3/32". I have never had a handle set this way fail yet and actually prefer tanged chisels to socket firmer for their ease of re handling among several other reasons.
For socket firmer chisels the fit is much more critical. I turn the stub tenon slightly oversize and then use a file to do the final fit. I Use a dremel with a small wire brush to remove all the rust from the inside of the socket. The steel will still leave a mark on the high spots of the tenon to show where to file. It is important to keep the handle in the same orientation each time you trial fit it to the socket because most are not perfectly round. If I get a really tight fit hot hide glue will gold it. If the fit is not so tight you may have to use epoxy as hide glue will not fill gaps.
