Super chainsaw chain question?
>I was watching "Modern Marvels" TV show and they discussed the stuff used by firemen. They mentioned that somebody makes a super chain for chain that they can use to hack through most anything to rescue people. Has anyone seen one of these? What does the chain cost? Who makes it? Would it be good for cutting bowl blanks etc and would it last longer than the regular stuff?
Re: Super chainsaw chain question?
Thomas S Stockton
>Barry,
Stihl makes a chain like that to fit there rescue saws I think it is REAL expensive. It's carbide tipped and probably wouldn't be real good at cutting up bowl blanks. I don't know if anybody makes a standard chain that is carbide tipped but you can buy chains designed to cut dirty wood which might be a good choice. I would start at a real chainsaw dealer and see what the can get or follow the link
Tom
let's try the link again
Thomas S Stockton
that didn't work
Thomas S Stockton
>OK so I can't post a link using the boxes bellow what did I do wrong
www.baileysonline.com
Rob Stokes in North Vancouver
>It's carbide chain and it's pricey, typically at least twice the price of regular chain. Harder and more pricey to sharpen too.
But I'm curious why you think you need it? are you wearing out chains or do you want longer between sharpenings? If it was that much better or ore cost efficient, everyone would be using it but the choice of professionals is still good old regular chain.
For regular bowl cutting etc. a regular chain will last just fine. If you're cutting a crotch and it's got dirt etc. in it, take a second with a garden hose and wash it out. That will extend the life of the sharpening.
If you're not good with a file or don't want to sharpen your own chain, buy another loop of regular chain and have it handy. That way when the one on the saw is dull you can swap them and take the dull one back to the shop for some work. I do this with my milling chains except I have my own sharpener. But swapping instead of sharpening makes for more productivity out in the field.
Whenever you swap chains, flip the bar over to help even out the wear. And after you've flipped the bar so it's got two or three chains run on each edge, take it in to have it squared and the chain groove re-sized. It only takes the shop a minute to do and it makes a huge difference to being able to cut straight. This is even more important is you're cutting in grit a lot.
Lastly, look around for a vegetable based bar oil. Remember that every drop of oil you put in your oil tank ends up in the environment in it's raw form. If you're using a petroleum based oil, you're basically dumping 10w-30 (or equivalent)out on your lawn - not cool.
The veggy based oils used to be more expensive but are now much closer in price to regular bar oils. They've got added tactifiers in them to make them sticky and we've found their lubricity to exceed regular petroleum oils based on bar/chain temps and bar life. For me, there's no going back.
You use a bit more (it typically flows better than petroleum based oils so if your oiler settings remain the same you'll notice an increase in the volume you use. You can also turn down the oiler if this is an issue), but you don't have to worry about slinging it everywhere, or overfilling your tank, or bringing wood into the shop that has spillage on it.
You can purchase the oil in 1 gallon bottles, but if you're going to use a lot or if you have buddy's with their own saws, buy it in 5 gallon pails and decant it to field-sized bottles.
Good luck
Rob
IMPORTANT - I forgot...
>...to mention that carbide chains is MUCH more prone to kickback. In fact with carbide chain, you can just about guarantee kickback will occur. I'm not sure if you've ever has a saw come back at you, but I assure you, it's something you want to avoid, regardless of the size of the saw and regardless of the protective equipment you're wearing (you ARE wearing chaps and head/eye/ear protection EVERY time you use a saw - right??)
With bowl and blank cutting it's not uncommon to use the tip of the saw to do plunge cuts etc. This is dangerous at the best of times, but it's not something I'd do with carbide chain, it's just not worth the risk.
Rob
Veggie based oil?
Gary Evans Tallassee, TN
>Hi Rob,
Any more info on the vegetable based bar oil? This is the first I've heard of it. Do you have a brand name?
Gary
John McGaw
>As others have stated, you probably don't want or need "real" carbide chain. It is outrageously expensive and is probably not nearly as tough as you might expect -- think of the times you've seen a circular saw blade lose a tooth. There is an alternative that may offer a bit of relief -- you can get chain which has a hard coating on the teeth which is purported to minimize blade dulling caused by "dirty" wood. I've used them and think that they may have helped me a bit (or it might be a placebo affect caused by me wishing for miracles from the higher-priced teeth).
I find that using a standard high-quality chain on a well-tuned bar with sufficient lubrication gives acceptable life. Every little thing that you allow to go wrong with a chainsaw seems to detract from the life of the loop as well as diminishing the safety of the user.
Did you do a preview?
Dan Donaldson
>Did you do a preview? Sometimes if you do, it wipes out the link. If you preview, use the back button to get to the original post page before you post, or just post directly with no preview.
Re: Veggie based oil? *LINK*
>Hi Gary:
The stuff I use is by the Greenland corporation out Of Calgary Alta. but I'm sure your local saw shop or arborist supply house can set you up. It's becoming more popular.
Rob
Veggy based bar oil
two types of carbide chain
Robin Corell in Atascadero Ca
>There are actualy two kinds of carbide chain. The more expensive of the two has a solid piece of carbide brazed to each tooth of the chain similar to a standard carbide circular saw. the less expensive type of carbide chain has a tungston carbide coating electrostaticly plated over the entire tooth. On the more expensive type once the chain is sharpend more than the distance of the carbide it becomes unusable. On the tungston carbide coated chain the chain can be sharpened down to the end and still have the carbide cutting effectiveness. It is the cheaper of the two types of carbide chain that is about 2x the cost of regular and is designated for cutting through asphalt shingles and other wrecking situations. I have no personal experiance with the carbide coated chains.
The more expensive of the two types is actualy closer to 8x the cost. at least that is what it cost when I got one for my father when he was building a retaining wall out of used RR ties. for a 14" bar it was pennies under $90. For that particular situatin it was worth the money. rather than sharpening the cain after 2 or 3 cuts it would cut over 50 ties before needing to be resharpened. But when it comes to sharpening it takes longer and requires a diamond file. My father has continued to use carbide chains for cutting dry almond wood which he uses for heating his home. most of his neighbors will not bother cutting up a standing dead almond tree as once dry it is a too hard on chains to make it worth the trouble. the carbide chain makes quick work of it.
For cutting turning blanks out of green wood I would not even consider a carbide tooth chain and a carbide coated chain would probably not be worth the extra money. If you are using square ground chain I would recomend switching to round ground as it will hold an edge longer. the square cuts faster but is more prone to losing its edge to dirt and debris.
Rob is 100% correct about the veggie bar oils. I have noticed a marked increase in milling speed since switching. you may not see much diference but it will add to the life of your bar and the time between sharpenings. I would also add that switching to a good full synthetic mix oil is also something you can do that will add to the life of your saw as well as the health of the enviornment. Some of these such as Stihl's ultra hp are bio degradable in addition to being low smoke. I was milling a 36" walnut tree withh an 89cc saw and a guy was bucking some of the limbs with a 33cc saw near me and I could smell his saw over mine. You can read that as inhaling oil fumes.
Cut safe and heep your tip out of the dirt
Robin
Fine But
>How to explain my saw smelling like french fries? |;-}}}}}}}
Re: Fine But
>I had the manual oiler hose pop off my Husky 2100 and proceeded to pump away on the oiler as I was milling. Instead of going on the chain/bar all the oil pooled behind the muffler and the thing got so smoky that I shut it down, stepped away and waited with the fire extinguisher. It never flared, but it sure didn't smell like french fries either!
Rob
Re: Fine Actuallyt
>HeHe.
Thanks for the info, however. They don't have any outlets in my neighborhood yet, but I've several arborist friends who may know of an alternative source.
mm
Ain't Wood Central Great?
>Thanks guys. I actually assumed the super duty chain would be ridiculously expensive and not necessary, but I wondered.
Butt he great thing is I learned about the vegetable base oil. Thanks for that.
And, Almond wood? Wouldn't it be better to sell it for turning blanks than to burn it? What does it look like? OTOH, if it looks like firewood, never mind.
Re: Fine Actually
>The Bailiy's brand of bio bar oil is cheaper that than Stihl bio+ but with shipping it comes out about the same. Any Stihl dealer should be able to order Bio+ bar oil and Ultra HP mix oil. My local dealer wouldn't and they are now explaining why to Stihl America.
Robin
Re: Fine But
>do you use an auxilary oiler on the tip as well?
Robin
Re: Ain't Wood Central Great?
>Almond is very pretty wood very similar to peach or apricot which are both closely related. It can be very dificult to dry and must be sawn through the center to keep it from spliting. The trees on my parents property are just over 100 years old and range in size from 10"-20" in diameter with very short trunks, usualy less than 2' to the first crotch. Most orchards are replanted at around 60 years old due to decreasing yeild, hence the tendancy to use it for fire wood. I have turned a few pieces and it is very prone to spliting if turned green and when dry is very hard and tough on tools.
Around here oak firewood is $175/cord and almond runs as high as $250/cord and most people think the diference is well worth the cost for its longer and hotter burn time.
Robin
Canola and carbide *LINK*
Tom Dunlap
>A number of years ago I spent an hour blocking up some large diameter logs into firewood with one of my employees. Between the two of us we used over a gallon of oil in the two saws. As we were putting the gear away I realized that we had effectively just dumped about a gallon of oil on the ground. That didn't sit right with me so I started to look into veggie oil. After reading a lot I decided to just head to the grocery store to buy the cheapest veggie oil I could find. After using various oils I bought a five gallon jug of canola/rapeseed oil for my chainsaws. I've never noticed any problems except when the weather is below about20 degrees. Then I needed to put the oil jug in the cab to warm up or it wouldn't flow. The oil in the saws would warm up with the motors and lube just fine.
There has been a lot written on veggie oils in arborist discussion forums. Almost all is positive. The brand labeled veggie oil for saw bars is mostly made using canola/rapeseed with some tackifiers to help it stick to the bar a bit more.
Oh, using bars that are over 28" or so might result in a bit of a dry tip though. Since most veggie oils are a bit thinner they fling off the chain. It's pretty unlikely anyone but a pro user would ever run a bar that long.
I have never heard of an arborist who has ever bought carbide chain for all of the reasons stated. Purchase and sharpening costs are high.
To learn how to sharpen chain, and almost any other chain saw or felling question, read Tim Ard's page.
Tom
Forest Apps
Re: Canola and carbide
>The bar on my saw is 37" (it's for milling - honest!) and I've never noticed any part of the bar being dry. On the contrary - the entire thing is always nice and oily. In fact I've modified the bar to accept an aux.oil feed (from a separate reservoir) at the tip end (puts oil directly into the groove) and while it's nice to have and I'll continue to use it, it's really not necessary with this oil (when milling softwood).
I guess the bottom line is that veggy oil in it's modified form (made for chainsaws) is every bit as good as petroleum based oil, and perhaps better. And if you live in a warmer climate and use the saw regularly, good old grocery-style oil would probably work for you as well. Either way - the oil slick you leave behind is biodegradable with veggy oil.
Rob
Re: Fine But
>Generally as a rule, yes. But as I just said in another thread, when milling softwood and using the Green Plus veggie oil, it's not really as much of a necessity.
Side note - to get the Aux. oiler's feed where it counts I drilled the bar so the hole intersects the chain slot. Then I made a Banjo bolt and made all the tolerances lose enough so the alignment of the Banjo bolt to the slot isn't imperative. Works great!
Rob
Re: Fine But
>Forgot to post a picture of "the beast" (Husky 2100, 37" bar modified for 3/8" chain (ripping). That's the veggie oil you can see in the aux. oiler. The 2100 has an automatic oiler plus a manual thumb pump if needed. the mills' an old 30" Alaskan opened up as far as it will go.
This picture was taken when we were making a 21' long beam. the saw died 1/2 way through the next cut (ign. module) but luckily Randy had his 285 with him so we were able to finish it off.
The muffler's off the saw right now and out getting a little attention. When it comes back, the saw will be putting out a little over 7 HP :)
Rob
