High tech cross linked finish
eliot d
>So what is such a finish? I have been told by a nationally -known finisher expert that, because I don't know about such finishes, I 'd better not fool with them -- that I should pay for a "professional". I figure , though, that I have to learn sometime. What is a professional , anyhow? why can't I learn what they know? I am a "professional" wood turner, for example. But I wasn't always one. I took the time to learn --mostly self taught( although I have taken some classes.) I just don't buy it that I can't figure it out sooner or later, even if I make some mistakes along the way. I could use some moral support.
Re: High tech cross linked finish
Surprising *LINK*
>You got such a response. The experts I've had contact with (Jeff Jewitt and Michael Dresdner) are usually ore than happy to explain such stuff. While I have a basic understanding, I'd rather poinnt you to Jeff Jewitt's site and let you go through his Articles section, [c&p - http://www.taunton.com/finewoodworking/pages/w00060.asp ] then log in and post your question and follow ups on his General Finishing Forum. This ain't alchemy or secret formulas that you need a magic wand to make work.
Homestead
JohnKJordan in East TN
>>...What is a professional , anyhow?
Formost definitions of a professional are a person engaged in a profession and a person who receives pay for what they do.
A lesser definition is an expert. (My favorite definition of an expert is "one who makes his mistakes in private.")
Alternative Definition
>"One who is paid to perform a service at a rate commensurate with his ability to hide his mistakes."
I didn't make it up |;-}}
Maybe ...
Joe Burke
>I won't swear this is the case, but most of these finishes need to be sprayed, and that may be where the rub comes in. Again, I'm speculating. There may very well be cross linked finishes that can be wipped or brushed, but I don't know.
Spraying can be done with very minimal equipment or a lot of equipment. There are a lot of variables, but anyone with a gun and compressor can spray.
Again ... pure speculation.
Robin Corell in Atascadero Ca
>when I was an apprintice I was told that everyone makes mistakes, but a journeyman catches their own mistakes and knows how to quickly and efficiently fix them.
Robin
Chrispy
>"Professional"
- A person that convinces you to make exactly the wrong decision for exactly the right reasons.
OR
- A person who gives advice, not only on the basis of measurable facts, but on the basis of experience and an intimate knowledge of the subject.
Both these definitions are evident in attorneys and Doctors to a greater or lesses degree.
On Topic
>Elliot,
Crosslinked finishes are [usually] polymer resin finishes that have a reactive agent added just before application that causes the film to cure in a particular way such that the resulting finish is both harder and more resistent to solvents. You can look up cross-linking on one of the online searche services or Wiki and get deeply into the chemistry if you are of such a mind [I'm not].
I use waterborne crosslinked finish ( General Finishes' Enduro with added cross-linker) for table tops that will see a lot of wear and spills. The crosslinking additive is very expensive ($35 per quart), and needs special precautions in handling and mixing. I apply it by HLVP spray, but I see no reason why it can't be applied by foam brush if you maintain a wet edge and do not overwork the film.
I have not tried a hand application so someone with more experience can jump in here. Since what I use is waterborne, it is a fast drying finish, and not the best choice for hand application.
Hope this helps a bit.
cutting throught the mumbo jumbo
Bill Tindall, E.TN
>This finish is likely also known as "conversion varnish", a product sold by every major finish supplier. It sprays just like lacquer. Read the directions and that will be all you need to know.
If you don't know how to spray, don't learn on a freshly made chest of drawers. But it is not hard to learn. I practiced on a piece of cardboard and water in the gun. Once you can spray a uniform coat of water move on to simple spraying jobs.
Jason Roehl in Lafayette, IN
Speculation it is...
>One of my favorite waterborne floor finishes is Bona Kemi's Mega. It's a one-part "oxygen cross-linking" finish. Basically, that means that once the water evaporates out of the liquid, the polymers start to intertwine (and perhaps chemically join). Full cure is about a week. This finish flows very nicely, and is fine for brushing (occasionally I'll have to fix a floor board or two, so I'll just tape them off and brush them). Most of the time I apply it with a T-bar floor applicator (pour it on the floor and "snowplow" it across the room).
But it does spray nicely, too, at least with an airless sprayer.
Jason
Correction
>That would be $35 per 12 oz jar. which translates to about $100 per qt.
