Adjusting Lunch box Planer Question.
>I have an older Dewalt Planer, the one that uses the resharpenable knives. I'm suspicious the in feed and out feed tables have sagged.
The question is, if I raise the head way up and stick a straight edge through it what should I see. Should the tables be tipped up slightly? If so, how much?
Re: Adjusting Lunch box Planer Question.
NickB
>Barry,
I probably have the same planer. The ends of the extension tables should be tilted up. I determined the amount empirically (trial and error). You need the up-tilt to reduce/eliminate snipe on shorter boards (longer ones I lift the end as the board starts and finishes).
Nick
Here's the fix (from Badger Pond) *LINK*
Tim Greif - West of Chicago
>The link below is an article from the Badger Pond archives on how to adjust the tables on virtually any lunchbox planer to reduce or eliminate snipe. I used this technique on my Rigid 13" planer and it worked quite well. IMO, you can never completely eliminate all traces of snipe, but this drill sure reduces it to an acceptable level.
Snipe be Gone
Rigid planer
tek-Brunswick, Ohio
>How do you like your Rigid Planer? I was going to go the the Depot and check look one over.
Thanks
Tom
Re: Rigid planer
dell schisler
>i have the planer 13" and like it Work's right out of the box No problums You get a extra set of blades You can keep them sharp If you want by using very very fine paper and honeing the blades I have't had to do mine yet I have 3 set's of blades I guess when i get to the end of my supply I will hone them del
Re: Rigid planer
>I like mine. It's the older TP1300. I've had it for a few years. Doesn't get a ton of use but when I do use it, it does a very decent job. Keep the table waxed and the rollers cleaned and you'll not have any problems. The chip collector chute works good with a shopvac. I've never been able to plug a 2" vac hose, even with heavy cuts.
Glenn Madsen, near San Francisco
>I have a Ridgid, old style, two blade model. And love it.
Some time ago, I had a scrap of melamine that fit thorough it, and I made a new, extended base. No more fussing with level. And waxing the base became much easier. Handled stock more easily, too. All for the cost of the odd offcut.
