Gluing melamine to melamine *LINK*
Dan Mitchell
>I need to repair some kitchen drawer fronts & will be gluing melamine to melamine. I see "Roo Glue" recommended for this, but I'm wondering if there's something more generally available (lumber yard, Borgs) that might also do the trick, based on anyone's experience.
Thanks
Dan
Roo Glue
Re: Gluing melamine to melamine *LINK*
Carol - now in NC Nebraska
>My experience with gluing Melamine, even with Roo glue, has taught me that a mechanical attachment also needs to be made. I'll be watvhing this one to learn more.
ScottS
>I've used Roo Glue Clear with very good results. While not available at The Borgs, there are several independent lumber yards that stock it in my area. If you can't find Roo Glue, perhaps some sort of two-part epoxy would work? Based on my experience, I'll suggest that white, yellow, and polyurethane glues probably won't work.
Carol suggests adding a mechanical fastener, which isn't a bad idea. My experience with Roo Glue suggests that a melamine-to-melamine glue joint is stronger than the surrounding wood... but the surrounding wood is particle board, so it isn't especially strong.
Dan Mitchell
>Thanks for the replies. The Roo Glue is available online, if nothing else. In looking more closely at this, I see though that the joint would actually be melamine to particle board. Basically, I'm cutting a new melamine drawer front which needs to be joined to the sides, so the edges of the front are particle board, while the contact point on the sides will be melamine. The original drawer (which, of course, FAILED ;-) was stapled at these joints. I was planning to shoot in a bunch of brads, or perhaps use small drywall screws.
Dan
Maybe I'll try this Titebond glue
Dan Mitchell
>Anyone have experience with this one? The local Woodcraft has it. Plus going there would give me an excuse to use that $20 gift card which has been gathering dust on a new set of chisels I've been eyeing!
Re: Maybe I'll try this Titebond glue
McKay Sleight
>The titebond brand for melamine works ok, but it has less body so it drips and runs like a bad cold. I really like the roo better. I wear gloves when putting the stuff on.
Dan Mitchell
>Thanks McKay, what I've read elsewhere supports that. Seems like the Roo is the way to go, guess I'll have to order some.
Dan
Robin Corell in Atascadero Ca
>The Roo Glue web site is notoriously bad at listing all their distributers. none of the three places I buy from are listed. Check at a wholesale lumber yard, one that sells to a lot melamine.
I also found it helpful to lightly scuff the surface of the melamine with 120 grit sandpaper
Robin.
>Gluing Melamine to particle board has less to do with the glue and more to do with the properties of each. Particle board, and certainly the coarse particle board of Melamine, is just not a structurally sound material. The glue will stick but the particle board will fall apart.
I hate to be repetitive, but consider a positive mechanical connection. In the case of particle board (whether it has a Melamine surface or not) that would be screws. Nails or brads won't help. They have no 'gripping' power. The simply have 'placement' power. They hold things in place, usually until the glue dries. In this application the glue is not enough, not because the glue isn't strong enough, or 'right', but because of the nature of surfaces being glued together.
Roo does pretty well on Melamine to Melamine surfaces. But a particle board surface cancels all bets.
So, since this is a a repair job, what are you doing to overcome the cause of the failure of the parts in the first place?
I'll put my bucket of cold water away now. :)
Re: My plywood guy has Roo glue.
Glenn Madsen, near San Francisco
Dan Mitchell
>Carol - Thanks for the reply, I'll probably go with the drywall screws.
Dan
Dan Mitchell
>There's a plywood dealer around the corner from here I keep meaning to check out (we've only lived here since last April). I'll give them a call.
The stuff has such a goofy name, I'm a little embarrassed to call about it! ;-)
Dan
>Get the ones with the very coarse thread. Sheet rock screws come with different threads. Then you will be a happy camper.
