OT Hot tub Relay question
>My friend has a hot tub that is about 16 years old and lately it has begun to eat relays. It has a 6KW heater and a 1.5hp pump motor on a 40 amp circuit @ 240 volts. The thing has gone through about four or five relays that turn the heating elements on in about as many months. They chatter and burn up the contacts or seize. Could it be the thermostat that is causing it to chatter? Anyone have any idea of what to do?
Re: OT Hot tub Relay question
Re: OT Hot tub Relay question *LINK*
Robin Corell in Atascadero Ca
>I know the link sounds suspiciously x rated, but it is legitimate. The gal that runs the site is an industry expert and has some really great info about repairing and maintaining an older spa. I did some checking and the prices are also consistently low.
I had a relay problem on a 15 year old spa and it ended up being the heater element. I also took the advice from the web site and replaced my 220v element with a 110v one because it is supposed to be easier on the relays.
Robin
spa babes
2nd that source
Mike Schwing from Md.
>I have had wonderful experiences with the people at Spa Babes. They are extremely knowledgeable and friendly, so much so that I wrote their president a letter suggesting a bonus for the folks that helped me through my recent hot tub motor replacement. You will never find better customer service anywhere.
Bill Schreiber, Litchfield, NH
>Barry,
If the relay is chattering, either its load for the contacts is over its design limit, each of the 6 relays were poorly manufactured (very unlikely) or the coil voltage is inconsistent.
Most likely, the heating element is drawing over its load (needs to be replaced), although a quick check with a volt meter will diagnose whether the coil voltage is low or inconsistent.
Note: not an electrician ; just spent a lot of time diagnosing my furnace and its relay issues this year.
Regards,
Bill
>Thanks Bill.
The relay was not working last night. I used a tester and got 240+/- volts across the line side and nothing across the load side.
When we turned the thermostat up or down the relay would make a chattering noise. Four to six times. Could not see any movement in the relay and it appears it was stuck.
I hooked up the heating element directly and turned it on for about one second, since the pump was not running. It pulled about 25 amps. Its rated at 6 kw, so that is pretty much right on.
The people that had been working on the hot tub had replaced the relay over and over saying they had a bad batch. My friend waited for a new batch and put one in herself. It did not last long enough for the tub to get hot.
I'm not an electrician either. Know just enough to be dangerous. Time to check the specs on the relay.
I was wondering is the temperature sensor on the stat had gone bad and was sort of flickering on and off, causing the relay to chatter.
